Author Topic: Possible to whiten the gray keys on a Model M?  (Read 72929 times)
Offline ed_
« on: Sat, 14 March 2009, 12:44:56 »
I want to dye all the keys on a Model M.  Is there any way to whiten plastic, or is there any paint that would actually work on those keys?
Offline lam47
« Reply #1 on: Sat, 14 March 2009, 12:48:46 »
I have seen yellowed keys whitened with peroxide but I don't think you will be able to get the grey dye out of the original plastic.
Any spray paint will stick but then it will wear off in time.
Even if you use a durable clear coat it will still wear I'm afraid.
I don't think there is a way to get them to stay white.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Sat, 14 March 2009, 21:33:12 »
Maybe start from the opposite approach-- at least for the standard-sized keys, you could substitute a white blank or sanded-clean keycap and add lettering yourself.
Overton130, Box Pale Blues.
Offline lowpoly
« Reply #3 on: Sun, 15 March 2009, 09:46:43 »
German Ambras have white keys.
