Author Topic: Tt eSPORTS Poseidon Backlit Mechanical Keyboard (MX Brown) - $69.99  (Read 2738 times)
Offline missalaire
  • Great Finder of Great Finds
Offline berserkfan
Offline missalaire
Re: Tt eSPORTS Poseidon Backlit Mechanical Keyboard (MX Brown) - $69.99
« Reply #2 on: Tue, 25 February 2014, 05:41:01 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823162027
That looks like an iONE board to me. Anyone have any idea?
Buy one, open it up and tell us.
Regardless of whether or not it's iONE, it seems to have gotten very positive reviews overall.
Offline REVENGE
« Reply #3 on: Tue, 25 February 2014, 05:44:57 »
You'd probably get more sleep in the long run if you coded up a bot to mirror SD.
Offline missalaire
« Reply #4 on: Tue, 25 February 2014, 06:00:42 »
I wouldn't have been able to sleep much earlier tonight anyways since I was up late doing school work. And this I saw from my Newegg subscriber email. Also, I don't stay up every night til the crack of dawn ogling for deals.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Tue, 25 February 2014, 09:17:38 »
I don't think it's an iOne. It has 1.25-1-1.25-7-1.25-1-1-1.25 bottom row which isn't typical of iOne at all, they use 1.5 and 6 spacebar. I would bet it's made by i-rocks, they love doing weird non standard combinations like that while otherwise generally seem to make a good quality.
Offline morpheus
« Reply #6 on: Tue, 25 February 2014, 10:04:55 »
Not a bad price for an illuminated Cherry Brown board.
Offline berserkfan
« Reply #7 on: Tue, 25 February 2014, 12:34:28 »
Wow Ivan, you really have good eyes to figure out that 7. But I guess more reason not to buy this keyboard; you're not going to get a replacement set of keycaps easily.
Offline ekw808
  • Ekw
« Reply #8 on: Tue, 25 February 2014, 16:24:27 »
I wish I could call my keyboard Poseidon, definitely should be listed as a selling point.
[One Keyboard at a time]
Offline karazi
« Reply #9 on: Tue, 25 February 2014, 19:25:26 »
I snagged one on impulse...already have a das and leopold browns but could use some backlighting and media keys...keep or refuse package?
edit: Kept it - I really like the keyboard, but there is a loud metallic pang every time I bottom out. Would o-rings or landing pads work well to eliminate that?
« Last Edit: Sat, 01 March 2014, 23:10:12 by karazi »
