Author Topic: Noppoo Choc Mini - keycap issues.  (Read 2517 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Tue, 25 February 2014, 20:08:53 »
I've only just noticed this since re-applying the keycaps back onto my Noppoo, but the f + j key are on different levels than the other keys.
Is this apparent on any one elses Noppoo or is this just mine? I've got other keycaps that I could replace them with, but that's not the point really, I love noppoos keycaps :(
pictures included:
« Last Edit: Tue, 25 February 2014, 20:12:53 by Fragil1ty »
你搞砸了
Offline Tony
Re: Noppoo Choc Mini - keycap issues.
« Reply #1 on: Tue, 25 February 2014, 20:59:39 »
Press harder on all keys till all keycaps are on the same level. Or you can use a chain-pump like all OEMs do.
« Last Edit: Tue, 25 February 2014, 21:01:33 by Tony »
Offline eddie
« Reply #2 on: Tue, 25 February 2014, 22:42:26 »
My noppoo choc mini has the same problem.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #3 on: Tue, 25 February 2014, 23:45:37 »
If you 're using Noppoo Choc Mini, please confirm here :D
Offline Fragil1ty
  • Abre los ojos.
« Reply #4 on: Wed, 26 February 2014, 00:19:49 »
All the keys are pressed down completely, I made sure of that, it's just annoying. It's a little bit of a pet peev of mine, I don't want to switch to new keycaps really.
Kind of annoying.
你搞砸了
Offline Tony
« Reply #5 on: Wed, 26 February 2014, 02:23:50 »
Keycaps are never on the same level so perfectly. Curved keycaps and staggered layout just skew the view even further.
You can learn to touch type, then you will not look at the keycaps again.
« Last Edit: Wed, 26 February 2014, 03:21:06 by Tony »
Offline BlueBär
« Reply #6 on: Wed, 26 February 2014, 07:22:18 »
If it's just the F and J keys, it's probably a small error in the molds for the keys with the nubs. You can try something like this though to fix it: http://geekhack.org/index.php?topic=42450.0
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Wed, 26 February 2014, 09:18:04 »
I would assume it was intentional, much in the way of how Cherry F J have a deepdish scoop, they only did the same thing with less elegance.
  • Frenzy Classic.
« Reply #8 on: Wed, 26 February 2014, 09:27:08 »
Are you sure? That is only intentional? We can do perfect, no error. I worried about round 3 if this issue happen :(
« Reply #9 on: Wed, 26 February 2014, 09:47:47 »
Perhaps it something Noppoo requested? Other Plum made keyboard do not have it this way.
  • Frenzy Classic.
« Reply #10 on: Wed, 26 February 2014, 09:55:37 »
Maybe... we just guess :)
