Author Topic: n-key rollover diodes.  (Read 2140 times)
Offline zeroni13
« on: Fri, 28 February 2014, 09:06:06 »
I need some n-key rollover diodes, but I don't know what they are, I know how NKRO works in theory but is the diodes special in any way or can I use any regular diode? I have made a list over parts I need for my phantom keyboard build, but I still need to find out what kind of diodes to get.
Will these work? If not would any of you be able to pick a diode from that site I can use?
https://www.elfaelectronics.com/elfa3~ex_en/elfa/init.do?item=70-005-57&toc=18701
Thanks in advance for any answer.
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline jacobolus
Re: n-key rollover diodes.
« Reply #1 on: Fri, 28 February 2014, 09:16:35 »
Do you need surface mount or through hole diodes? For through hole (or hand wiring a matrix), 1N4148 diodes seem to work pretty well. I’m not sure what kind of PCB you have, but the Massdrop Ergodox kit uses 1N4148W-7-F surface mount diodes. Plenty of other types should also work fine; I’m not sure what the cheapest options are. Note, ebay is also often a good source for this kind of thing.
Offline whiskytango
  • Don't touch the trim
« Reply #2 on: Fri, 28 February 2014, 09:33:47 »
I think as long as they are 1N4148 you are fine. And these are through-hole type which is what you need for a phantom. I'm sure you've seen it, but there's a parts list and some instructions on deskthority
I also highly recommend that you checkout WhiteFireDragon's youtube video for Phantom building.
Offline zeroni13
« Reply #3 on: Fri, 28 February 2014, 10:15:19 »
Thanks, I'll go for the 1N4148's I linked then. Thanks for a fast answer! ;)
