Author Topic: Model M case different material than keys?  (Read 72610 times)
Offline ed_
« on: Wed, 18 March 2009, 00:01:32 »
I tried dyeing a Model M.  The keys, and the stems from the few two piece ones, came out perfectly, but the case just wouldn't take the dye.  It would just become a darker gray, looking as if it were just a filthy keyboard.
There was no problem with the dye; I tried enough orders and variations with multiple dye baths and keyboard sets that I can rule out anything like that.
What is the difference between them, and has anyone successfully dyed the case of a Model M?
I suppose that I could just paint and seal the case; since it doesn't get touched often it should last for a long time.
Offline Chloe
  • Switch Kitten
« Reply #1 on: Wed, 18 March 2009, 06:37:17 »
The case is most likely a different plastic, possibly ABS or HIPS. Some plastics (nylon, PBT) take the dye better.
Offline Chloe
  • Switch Kitten
« Reply #2 on: Wed, 18 March 2009, 08:12:22 »
That would explain the lack of yellowing on older boards. Melting point is only 80°C so more heat won't help.
