Author Topic: [Q]Looking for my first switch sampler kit, which one should I go with?  (Read 1827 times)
Offline combataran
QWER6, WASD, CM Demo Board, Desk Cherry MX Sampler or the Max tester kit? I would prefer the cheaper one, but I do consider things other than the price.
http://www.qwerkeys.co.uk/product/qwer-switch-testing-kit/
http://www.cmstore-usa.com/mechanical-key-switch-demo-board/
http://www.wasdkeyboards.com/index.php/wasd-sampler-kit.html#ad-image-0
http://www.mechkb.com/deck-cherry-sampler
http://www.maxkeyboard.com/max-keyboard-keycap-cherry-mx-switch-o-ring-sampler-kit.html
Also, I don't think CM USA ships to Malaysia(where I'm currently residing).
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Pacifist
  • on hiatus
Re: [Q]Looking for my first switch sampler kit, which one should I go with?
« Reply #1 on: Sun, 02 March 2014, 20:44:19 »
cm
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Sun, 02 March 2014, 22:17:36 »
Yep, the Cooler Master version is the most complete. Although it's tough to find Clear switch boards, they are my favorite, so you should definitely try them too.
« Reply #3 on: Sun, 02 March 2014, 23:14:40 »
Another vote for CM.
It is closest to a real keyboard (plate + case), comes with 6 switches (some have less), and makes a really neat display case for special keycaps.
QWERkeys is probably the next best - it simulates switches on a plate.
Raw switches are not much use, but it doesn't hurt to have a few lying around in case of an accident.
Offline SonOfSonOfSpock
« Reply #4 on: Mon, 03 March 2014, 00:47:16 »
CM then Qwerkeys. They both give you the ability to put the switches in a case like object. The raw switches plus keycaps are better than nothing, but having something stable is great. I give the nod to CM because they have a clear switch. Qwerkeys has a white switch instead which is much more rare and not as useful to test.
