Author Topic: software for complete keyboard remap - OSX  (Read 4166 times)
Offline Lynge
    • http://lynges.net
« on: Thu, 19 March 2009, 11:34:40 »
Hello
I am looking for a way to remap alot of the keys on my keyboard. Just got OSX on my Workstation and nothing is like it should.
Using a Cherry G80-3000 and Home/End does not work and curly braces are hard to produce. So I would like to remap a lot of the keys to something else.
Can anyone suggest a good piece of software for this? It has to work on OSX :D
Many thanks in advance
Offline Lynge
    • http://lynges.net
« Reply #1 on: Thu, 19 March 2009, 18:52:25 »
Heh, I found something. Not that I did not search before asking, but just not good enough it would seem.
For those that may find this in the search for a solution, you can find software for it at these two links.
http://doublecommand.sourceforge.net/
and
http://scripts.sil.org/ukelele
The first is for mapping function/modifier keys (can make windows-like end/home) and the second is for all the "normal" keys. And it is just great :)
Sorry for posting the obvious, but I had alot of trouble finding anything on this, and I just want to help others trying to solve the same problem :D
Offline wellington1869
« Reply #2 on: Fri, 20 March 2009, 13:49:07 »
there's also this free keyboard remapper for osx:
http://mac.softpedia.com/get/Utilities/uControl.shtml
"ucontrol"
[edit: actually nevermind, I dont think its a full keyboard remapper]
using: ms 7000/Das 3
