Author Topic: What Pointing Device Are You Using Now?  (Read 331730 times)
Offline Touch_It
Re: What Pointing Device Are You Using Now?
« Reply #200 on: Fri, 07 November 2014, 13:08:55 »
Logitech G502 Proteus Core.  Second (maybe 3rd) best mouse I've ever used.  Logitech G500 is the best mouse ever imo.  followed by either the MX revolution (RIP)  or the 502.  I can't live without the extra buttons left and right on the scroll wheel.  Double edged sword because that gives me a very narrow selection of mice to choose from but luckily logitech makes great mice.
Currently at work though I'm using a Razer Lachasis until I can fix my G500.
Offline yasuo
  • spanengan puyeng newbie
« Reply #201 on: Fri, 07 November 2014, 23:23:50 »
still lua :eek:
Logitech MK220 Colemak DH
Offline Bucake
« Reply #202 on: Mon, 10 November 2014, 17:34:15 »
G400.
what i really want (to try) is the FK shell with FK1 internals and omron switches.. but i can't do that **** myself :(
.....or a 3366 in a aurora-like shell (small and light)!
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #203 on: Sat, 15 November 2014, 20:41:23 »
this guy
microsoft sculpt ergo mouse
got it for 20$
its actually pretty comfortable after you get used to it. its like a hybrid of a claw mouse and a vertical mouse. tracking isnt bad either it actually works for gaming ok
Offline SpikeBolt
  • √(4) != -2
« Reply #204 on: Wed, 19 November 2014, 08:54:43 »
Currently at work, using a DeathAdder 3.5G. Wouldn't recommend it because it has a glossy surface and sub-par (for me) ergonomics. At home I have a Roccat Kone XTD and it's so much better. 10/10
Offline davkol
  •  Post Editing Timeout
« Reply #205 on: Wed, 19 November 2014, 12:14:37 »
A small Wacom Intuos.
Offline fxtannier
« Reply #206 on: Sat, 06 December 2014, 14:52:06 »
I don't know if this would count as mine don't point  :)) . I actually been using an Apple Trackpad for 5 years now. I really like this for general computer stuff such as surfing the internet and word processing. For gaming I do switch to a regular small logitech mouse cause I find it more easy for gaming. I really like it due to it's customizable gesture nature. I can three swipes or two swipe in a certain direction to process almost any kind of command I set it to. Really useful.
« Reply #207 on: Sat, 06 December 2014, 21:33:24 »
I use an apple trackpad with my hackintosh just for the gestures, it makes working so much quicker!
Offline geogga
  • gosh dang GH and their GBs
« Reply #208 on: Sat, 06 December 2014, 22:33:20 »
Mionix avior 7000. had a few issues but solved and went away.
Looking for a mousepad, not sure if i should buy another qck.
I recommend the avior!
How is the Rival? I've seen the razer taipan, my avior, the rival, and the fk1. Was stuck on the avior and rival because:
razer: razer. tis all I need to say.
fk1: heard it's plagued with issues. scroll wheel to hard sidebuttons to sensor, who knows.
Offline daerid
    • Rossipedia
« Reply #209 on: Sun, 07 December 2014, 02:29:31 »
went a little hog wild for Logitech. Currently alternating between G600, G602, and G502
Offline munch
« Reply #210 on: Sun, 07 December 2014, 09:55:45 »
Rival has questionable build quality, and straight up bad material choices. the rubber wears off in a few months. you'll notice your hands being covered in rubber after gaming on it for a while :p
it's also really heavy and grips very differently from the Avior.
I wouldn't recommend a QcK when there are so many better options out there - but it really depends on your preferences. if you could describe a little how you would like your mouse to glide...
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #211 on: Sun, 07 December 2014, 10:21:52 »
Logitech G600 right now, I have to finish its review. I've used a Razer Naga quite a lot in the past, but this thing really just feels wrong in my hand...  :confused:
And yup, the Logitech G602 feels a whole lot better than it does.
« Last Edit: Sun, 07 December 2014, 10:23:30 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline daerid
    • Rossipedia
« Reply #212 on: Mon, 08 December 2014, 01:08:14 »
errrr... wat
Offline Freebird
    • SSRCG
« Reply #213 on: Mon, 08 December 2014, 12:35:33 »
Just got myself a Zowie FK1 to replace my dodgy Sensei pro  :thumb:
Offline daerid
    • Rossipedia
« Reply #214 on: Tue, 09 December 2014, 11:38:22 »
Isn't it just "Sensei"? I didn't think they had a "Pro" model.
Offline wetto
« Reply #215 on: Tue, 09 December 2014, 14:36:51 »
errrr... wat
I know ergonomics do not always apply the same way to everyone, but the Logitech G600 just feels wrong to just about everyone, be it Palm, Fingertip or Claw grip users.
In that way, the Logitech G602 is a whole lot better than it is, even though it's quite a big mouse.
My collection:
Offline wetto
« Reply #216 on: Wed, 10 December 2014, 09:05:48 »
CM Storm Octane, Cooler Master's new gaming combo, now using the AVAGO 3050 sensor instead of the crappy Pixart PAW 3309DH the previous one had:
But...
Yup, still sucks and internals are full of low quality components. But, compared to the CM Storm Devastator, at least now it's just a bad gaming combo instead of plain garbage.
« Last Edit: Wed, 10 December 2014, 09:14:02 by wetto »
My collection:
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #217 on: Wed, 10 December 2014, 14:57:38 »
But...
Wetto, remind me to stalk you or something when the new CM products come out later next year  :p
Offline wetto
« Reply #218 on: Wed, 10 December 2014, 16:21:13 »
But...
Sure, as far as I know, there's the CM Storm Alcor+ (with side-grips and Pixart PMW 3310 sensor) and a mouse that looks just about the same as the Steelseries Sensei coming up (you could say it's a better version of the Recon), but there may be others I do not know.
Anyways, now that I finished reviewing both CM Storm gaming combos, I can go back to reviewing mice that are actually interesting and good, such as this lil' thing I got from a modder friend:
It's a replica of the extremely rare "Razer Cypher Deathadder":
According to Razer itself, only 15 of these were produced, but finding one is almost impossible. And the most interesting thing is, Cypher himself does not uses this mouse nor any Deathadder.
The replica in question is actually quite nice, I had a Deathadder a few years ago and this one surely isn't worse than it, since there is a Deathadder 3.5G inside of it (though the original version used 3G internals).
« Last Edit: Wed, 10 December 2014, 16:32:34 by wetto »
My collection:
Offline daerid
    • Rossipedia
« Reply #219 on: Thu, 11 December 2014, 22:53:26 »
I'm definitely the odd duck then, I think it's damn near perfect. I'd absolutely love a mouse with it's shape and standard forward/back buttons.
But then again, I absolutely love Wingman-inspired shapes. I still have one of these bad boys:
To this day, still one of the best feeling mice I've ever used. Sensor sucks tho :(
Offline munch
« Reply #220 on: Thu, 11 December 2014, 23:36:14 »
I'm trying out the G302 from Logitech right now. strangely very natural to grip for me, despite having the oddest shape that looks nothing like any ergonomic mouse out there.
so far, it is making me question what I've been looking for as a grip in a mouse before :p
it's a bit narrow in the front, which is fine, but you should definitely try it out before using it.
buttons are great, scroll wheel is alright.
can't comment much from a sensor performance perspective yet. I don't have my proper gear available, and using a very ****ty slow laggy monitor for the time being. but it should perform similarly to the G100s, which is good.
Offline Creizai
« Reply #221 on: Fri, 12 December 2014, 22:25:28 »
You know whats funny? I went out found a 1010 on amazon for $25 shipped.  I ended up buying it knowing that it wouldn't live up to replace my fps mouse.  I actually love the damn little thing, I just wish the mouse hertz could at least hit 500hz instead of the 315hz it keeps hitting.  I know the 2020 is actually somewhat usable for desktop and rts duty.  They all hit $100+ and I just can't justify that.  I'm thinking about opening her up and seeing if I can swap in the guts from a Zowie MiCO.  CM Storm Xornet is on the way though, maybe that will satisfy me.
Offline daerid
    • Rossipedia
« Reply #222 on: Sun, 14 December 2014, 23:31:47 »
The 1010 was a phenomenal mouse, except the mouse buttons were complete rubbish. If you do end up replacing the internals, I'd strongly suggest swapping out the switches for some Omrons or something similarly high quality.
Offline wetto
« Reply #223 on: Wed, 17 December 2014, 21:28:16 »
A Fake Razer Abyssus 3.5G Mirror Edition.
Just finished making an article of how to recognize the fake versions and all the differences between the original and fake, although it's in Brazilian Portuguese:
http://adrenaline.uol.com.br/forum/hardwares-em-geral/551765-tutorial-como-identificar-um-razer-abyssus-3-5g-mirror-edition-pirata.html
But then again, I can just post some pictures here...
And yes, that's an AVAGO 5050 IR sensor there.
The funny thing, is that ALL fake mice have the SAME Serial Number: PM0949024101311
« Last Edit: Wed, 17 December 2014, 21:31:55 by wetto »
My collection:
Offline wetto
« Reply #224 on: Fri, 19 December 2014, 22:06:15 »
Using a brand-new Razer Naga 2014.
Sure, it has a good number of improvements over the original, but somehow I really prefer the ergonomics of the older one...
My collection:
Offline Blaklyte
« Reply #225 on: Mon, 22 December 2014, 09:55:08 »
Razer Copperhead, had this since it came out in 2005
Offline daerid
    • Rossipedia
« Reply #226 on: Mon, 22 December 2014, 11:06:48 »
^^^ Had a green one. Great f'in mouse.
Offline Blaklyte
« Reply #227 on: Mon, 22 December 2014, 13:54:33 »
I really like it, I'm just sad that at some point it will stop working and I can't really find a mouse on the market that I like right now.
Offline Lurch
« Reply #228 on: Mon, 22 December 2014, 14:22:35 »
Kensington Slimblade
Quote from: Flyersfan1
« Reply #229 on: Fri, 26 December 2014, 16:57:37 »
CST2545-5W Trackball I got for christmas, it's my first trackball so it'll take some time to get used to and I still need to break in the bearings but so far I really like it.
Offline Clearly Superior Username
« Reply #230 on: Tue, 30 December 2014, 10:36:50 »
Razer Abyssus 2014. really liking the shape and sensor. im still trying new things though, really want to try a trackball as well
Offline dante
« Reply #231 on: Tue, 30 December 2014, 12:23:52 »
On CST's website they are hinting about an upgraded PCB/Laser for the L-Trac.  Do you know anything about this?
« Reply #232 on: Tue, 30 December 2014, 16:44:34 »
No but there are a few things they could change to make it better like more dpi options and the ability to change polling rate. But other than that I don't see much they could improve. Maybe accuracy?
Offline dante
« Reply #233 on: Wed, 31 December 2014, 09:38:47 »
Here is the response I got:
Quote from: email from CST
We are planning on just releasing the info on the new PCB on our website probably in the next few days.
We are currently selling the new ones now but getting one depends on where you buy the L-Trac from and whether they have bought L-Trac's from us in the past few weeks or not, I suggest asking the seller and maybe requesting one. You will be able to tell if the trackball has the new PCB by the "R2" next to the Model # on the label on the bottom of the trackball, all L-Trac's with the new PCB have the "R2". Please let us know if you have any other questions.
« Reply #234 on: Thu, 01 January 2015, 19:24:09 »
Guess I got the new one, mine has R2 stamped after the model #. I wonder what they changed?
Offline dante
« Reply #235 on: Thu, 01 January 2015, 19:30:20 »
Here are the new details.
Quote from: CST
Newly Designed PCB and Upgraded Laser Sensor Details
Our Newly Designed PCB and Upgraded Laser Sensor offers the same level of reliability and control that L-Trac users have come to expect over the years. All the same individual L-Trac models will continue to be available and they will all have the new PCB and Laser Sensor. All L-Trac models will continue to offer the same CPI (800, 1600, 400) which is still the highest of any trackball available today. New features are also available and include:
- Field Programmability
- Improved Precision Tracking
- The ability to change out the solid black ball for any other colored 2.25” ball (the same size as a regulation billiard ball). (Note: under standard operation any colored ball will work but the solid black ball has the best performance)
The new L-Trac's are Available Now, to see if you have one simply check the label on the bottom of the trackball and if there is an “R2” next to the model number then you have an L-Trac with the New PCB and Laser Sensor.
Offline Valen
« Reply #236 on: Thu, 08 January 2015, 01:13:22 »
Office: Logitech G5 (Win).
Home: MX518 (Win) / G500 (Mac) / Anywhere Mouse MX (MBA).
Yes, I like Logitech.  ;D
Offline Novus
  • Mondai nothing~
« Reply #237 on: Fri, 09 January 2015, 22:30:08 »
Wetto you should definitely get/start your own website  ;)
That's one of my favorite mouses.
« Last Edit: Fri, 09 January 2015, 22:44:25 by the1onewolf »
Offline wetto
« Reply #238 on: Mon, 12 January 2015, 04:41:10 »
I did, a few weeks ago...
www.hardwaredissect.com
BTW, the new Naga 2014 surprised me a lot. All of the flaws I had mentioned on my previous Naga review (Naga Molten) were fixed, plus there are many enhancements on build quality as well. Better plastic, better internals, better coating, and surprisingly, the new Philips Twin Eye PLN 2034 is not only a good sensor (unlike the previous ones), but it may as well be the best laser sensor ever used on a mouse, the LOD is just insane when properly adjusted, there's no Z-Axis problems, no durability problems, no tracking problems, doesn't seems to have Dynamic DPI Scaling as far as I've seen..
« Last Edit: Mon, 12 January 2015, 05:01:27 by wetto »
My collection:
Offline woll3
    • ESL Profile
« Reply #239 on: Mon, 12 January 2015, 05:48:03 »
It is actually adjustable, altough i need to read up on the exact numbers and featureset because apparently there are differences within the 8200cpi models.
and im still waiting for my PTE Taipan..... :(
Offline ice31000
  • Just a block of ice on a journey of clacking.
« Reply #240 on: Mon, 12 January 2015, 13:40:24 »
Currently using the SteelSeries Sensei Raw. I love the rubber feel that the mouse house.
iceyy
Offline Novus
  • Mondai nothing~
« Reply #241 on: Tue, 13 January 2015, 18:18:26 »
It's nice that they fixed the Naga. I wonder if they made internal quality improvements on the DA Chroma from the DA 2013. I seem to remember people complaining about the clicks wearing down quickly.
Also, Whooo! Hey congrats on the new site launch! :thumb:
Keep up the good work and good luck. I hope you expand your content in both english & portuguese and maybe start a forum/community too!
« Reply #242 on: Sat, 24 January 2015, 18:31:48 »
I relubed the bearings in my CST L-Trac with a thick lube and it is now buttery smooth and feels a bit heavier to move the ball. I think I'm in love.
Offline Valen
« Reply #243 on: Mon, 26 January 2015, 02:09:15 »
Just replaced those 3 steel balls and my MS Trackball Explorer feels like new again. :)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #244 on: Mon, 26 January 2015, 04:27:40 »
Nothing better than playing with a well-lubed ball  ;D .
Offline minh278
  • In life we will only fall, How far will we fall?
« Reply #245 on: Mon, 26 January 2015, 23:13:57 »
Using Logitech g700s, happy with it though im curious as to how other mouses feel compared to it. The only other mouse i had was a mx518, but that died.
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
Offline Kira
  • <3 <3 <3 <3
« Reply #246 on: Wed, 28 January 2015, 03:54:00 »
Using my Steelseries Intellimouse 3.0 (Taiwanese model). Switched from my WMO about a month ago.
Offline aceps00
« Reply #247 on: Wed, 28 January 2015, 08:04:16 »
Currently I'm using the Roccat Tyon  :)
Type Heaven / IBM Model M
Offline Lostwave
« Reply #248 on: Wed, 04 February 2015, 16:02:38 »
Microsoft Trackball Explorer.  Luckily I grabbed a bunch of them way back when because you can't get them, or anything like them anymore.  Any other mouse drives me crazy.  The sculpted shape feels good in my hand too.
But I am oldschool, I spend 90% of my time without touching the mouse.
Natural Keyboard Pro ~ Ducky Shine3 ~ IBM M 122 ~ IBM F ~ KBC Poker 2 ~ Atari CX-85 ~ Touchstone 2
« Reply #249 on: Thu, 05 February 2015, 23:02:41 »
epzy cursed my deathadder.
it was working fine until we had an argument about it. (he said it was crap and i told him mine has been working fine for 2+ years)
now it's jittery as hell and constantly miss-clicks.
i hate you epzy.
