Author Topic: Does keycaps hits LED lights when bottom out?  (Read 5933 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Tue, 04 March 2014, 22:11:03 »
So I've finally modded my Poker II with LED recently.  And I noticed the LED is actually a little bit taller than the switch housing.
56324-0
This is actually not my pic but as you can see the LED sticks out a little bit.  And I always thought when bottom out the wouldn't the keycap hit the top part of the housing?  So wouldn't it hit the LED?
Though as I'm typing now I don't really feel it so this makes me wonders.
Also now that I think about it, would it be better to use a shorter LED like this or something?
56326-1
Something similar to this?
Or is the stem actually long enough so when bottom out the keycaps don't actually hit?  Anyone knows?
Offline Dreamre
    • kbdlife
Re: Does keycaps hits LED lights when bottom out?
« Reply #1 on: Tue, 04 March 2014, 22:13:12 »
Yeah, you either need "flageless" (without the wings at the bottom) LEDs or 2x3x4 LEDs (the square one you showed above).
I think as long as you don't hear a thock noise, you should be fine.
Offline RabRhee
« Reply #2 on: Tue, 04 March 2014, 22:23:26 »
The switch stem only moves 4mm before bottoming out. Typically a key stem is more like 5mm or 6, depending on your keys. So when the stem bottoms out theres still fresh air between the key and the switch, unless you are using some really shallow throw keys or keys with a curved inside. You could check the length of your key stems to confirm this.
I think you will be ok, but shorter LEDs would be safer if you swap caps later on without checking.
edit: It may also depend how far out the LED is, the side of a key may hit it more than the top. Thats hard to gauge from your photo.
« Last Edit: Tue, 04 March 2014, 22:27:06 by RabRhee »
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline Photoelectric
« Reply #3 on: Tue, 04 March 2014, 22:25:14 »
Yeah, 2x3x4mm LEDs are the best in terms of not interfering with anything, in my experience.
http://geekhack.org/index.php?topic=54702
Offline Hyde
« Reply #4 on: Tue, 04 March 2014, 22:52:49 »
Ohhhh thanks for the replies guys.
lol yeah I had to clip mine to make them "frangeless".  So far seems to work ok.
Ahhhh this helps a lot thanks !!!
I've already modded mine and I'm most likely will be too lazy to re-do it again.  But I'll keep this in mind for next time.  :)
Offline Dreamre
    • kbdlife
« Reply #5 on: Tue, 04 March 2014, 22:56:26 »
If you clipped it, you don't need to worry about it! It's all good :D.
Offline OperationT
« Reply #6 on: Fri, 04 December 2015, 00:07:05 »
I just measured a stem of one of my keycaps (Vortex PBT, Cherry profile, number/backspace row (row 1?)). The key stem is indeed 7mm, but I think the mini-wall-thingies (as pictured below) will hit the switch top-housing at bottom-out instead of the top of the keycap, and the distance between the end of the keycap stem and the wall thingies is only 3.5mm. And then there is the fact that the end of the keycap stem does not sit flush with the top-housing, and sits about 1/3mm higher than the switch's top housing. That means there is a distance of 3.5mm + 1/3mm ~= 3.83mm from the wall thingy to the switch top-housing.
And as you said (I measured it myself too), that the switch stem travels about 4mm to bottoming out.  So the wall-thingy should hit the top-housing before the switch stem travels the whole 4mm. So I think OP's picture's LED (top one) will hit one of the wall-thingies, since it's protruding beyond the top-housing. As a separate, not-so-scientific test, I tried wiggling two keycaps at bottom-out position on two switches: one with LED (the same type as OP's), and one without LED. The one without LED seems to have more wiggle room, and the one with the LED clearly has less wiggle room in the direction of the LED.
I'm pretty sure the LED gets hit. But I don't mind that it is being hit. I think what matters is: which one feels and sounds better when bottoming out? Hmm.. I'll leave that for one of the keyboard gods out there to answer..
--EDIT--
OK, silly me. I realized I could also check out the gap between the keycap and the switch at bottom out between the switch with LED and the switch without. As shown in the second picture, the one with the LED hangs higher!
--UPDATE--
Okay, I can't believe I recorded the two sounds, but I did. I'm done after this! No more!
You guys decide which one sounds better. The one with LED sounds lower pitch. The order of the key presses goes like this:
1) No LED (soft, slow presses)
2) LED (soft, slow presses)
3) No LED (soft, fast presses)
4) LED (soft, fast presses)
5) No LED (hard, slow presses)
6) LED (hard, slow presses)
7) No LED (hard, fast presses)
8 ) LED (hard, fast presses)
« Last Edit: Fri, 04 December 2015, 00:51:44 by OperationT »
Code 104, Ergo Clears (65g)  |  VA87M, Zealios (65g)  |  RealForce 87U (55g)
