Author Topic: Orion TKL Group Buy  (Read 847102 times)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Orion TKL Group Buy
« Reply #200 on: Mon, 24 March 2014, 12:00:24 »
Ordered one. This is going to be an expensive month for keyboards. :D
EDIT: I guess I will need to start sourcing some switches and stabilizers.
EDIT2: These should fit, right?
Those are definitely pcb mount cherry stabs, so they're good
Not too sure on imsto's shipping speed, though :P.
I'm getting mine from GON's site. There are also switch stickers on that site, although only in red.
You can get switches from mechanicalkeyboards.com. ^^
Something about Imsto I am missing? Is he MIA?
I'll get the switches sorted out, so just a checklist for me, and other of what I will need to make this board work:
- MX switches 87x
- Cherry Stabilizers (6.25 or 7 unit spacebar, depending on Winkey/Winkeyless)
- Switch stickers (Optional, but I want them)
- Mini usb cable
- LEDs, colour of choice
- Resistors (for LEDs, resistance depending on colour) Not necessary
Am I forgetting anything?
« Last Edit: Mon, 24 March 2014, 12:21:46 by JaccoW »
|||My other keyboards :
x
Offline CK Briefs
  • formerly calvins1
« Reply #201 on: Mon, 24 March 2014, 12:14:51 »
Well it is imsto.CN; and i usually hate chinese shipping :S
GON's shipping cost is pretty high though haha
I had no idea imsto had cherry stabs honestly
Cross out resistors on that list, all SMD soldering is already done, as confirmed by Sifo and Photoelectric-- you only need switches and LEDs
Other than that, your list looks good ^^ And don't forget a good set of thick PBT or GMK abs key caps to really bring out the LEDs; or else, they'll bleed and look all crappy ):
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline cirrus82
« Reply #202 on: Mon, 24 March 2014, 12:20:59 »
On that note, does anyone have good recommendations for keycaps that look good backlit?  I like the look of the ones on the CODE keyboard (even though they are thin and flimsy) but they are not sold independently of the keyboard.
Offline Photoelectric
« Reply #203 on: Mon, 24 March 2014, 12:22:32 »
You can get a set of Ducky Shine keycaps from mechanicalkeyboards.com.  Trouble is that those are made for switches mounted upside-down on Ducky keyboards, with LEDs pointing up.  If you use those on "normally" mounted switches, the LED will be closer to the front of the keycap, and the legends won't be as well illuminated.  Unless you get transparent switch covers too to disperse the light.
« Last Edit: Mon, 24 March 2014, 12:24:12 by Photoelectric »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #204 on: Mon, 24 March 2014, 12:25:14 »
Thanks, I was planning to put Ivan's Black on Black pbt dyesubs on there with red leds and clear switch covers. That should make it an ominous little board. :P
And match my computer case as well.
That should make my desk primarily Korean XD
x
Offline CK Briefs
  • formerly calvins1
« Reply #205 on: Mon, 24 March 2014, 12:28:11 »
Same here :P Although the front LEDs on my case kind of died out, most of it is still red :P
Wish i had clear switch covers though; but I think i've spent enough on one keyboard for at least a couple months :P
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #206 on: Mon, 24 March 2014, 12:45:29 »
You have a Zalman Z-Machine case as well? I think by the end my keyboard will be as expensive as the case was originally.
I should open it up some time and take some measurements of the pcb of the front panel connections.
Design a new one and replace the Firewire with USB 3.0 or something.
x
Offline CK Briefs
  • formerly calvins1
« Reply #207 on: Mon, 24 March 2014, 13:24:56 »
Ah I don't have a Z-Machine case, I meant the red/black colour scheme + Ivan's pbt :P
Offline elton5354
« Reply #208 on: Mon, 24 March 2014, 20:16:03 »
What do you guys think of the lightsaver v2? Same specs as the original one but different case.
« Reply #209 on: Mon, 24 March 2014, 20:19:08 »
I love my V1 with the flat back.  The stepped back side is a little odd.  Same reason I find the Orion case and other related designs a little funky when looking from the back.
Another great thing about the original LightSaver is the relatively low height at the front--I think the new design would make it overall taller and require a wrist rest.
Offline ninjadoc
« Reply #210 on: Mon, 24 March 2014, 20:22:09 »
I want one! I like it! :)
Offline elton5354
« Reply #211 on: Mon, 24 March 2014, 21:00:53 »
They're the same height.
Offline cirrus82
« Reply #212 on: Mon, 24 March 2014, 22:02:27 »
I want one!
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #213 on: Tue, 25 March 2014, 03:53:35 »
Got my invoice and paid.  :thumb:
x
« Reply #214 on: Tue, 25 March 2014, 15:59:26 »
Sad to say something came up and I can't afford this for the next little while. Enjoy everyone :( it's a sweet board.
Offline witbliz
« Reply #215 on: Wed, 26 March 2014, 06:03:17 »
OMG Elton u made my day ! I have been waiting for the lightsaver ! I will be the first person to buy that !
« Reply #216 on: Wed, 26 March 2014, 06:05:01 »
Question is, will it come in PINK!? (yes, I'm pretty sure it won't :( )
Offline Stabilized
« Reply #217 on: Wed, 26 March 2014, 16:39:31 »
I am thinking of converting my QFR from ISO to ANSI, if I bought just the plate could I do this with the QFRs current PCB?
Looks to me that the QFRs PCB has holes for the ANSI layout, just need a plate for them to mount to.
« Reply #218 on: Wed, 26 March 2014, 19:19:29 »
These plates are designed to be mounted in an aluminum case. Besides, QFRs are so cheap, why not just get a new ANSI version?
Offline Stabilized
« Reply #219 on: Thu, 27 March 2014, 02:18:28 »
I thought this might have been the case, worth a try though.
The reason I wanted to try this other then getting a new keyboard was money saving, as it is $31+shipping (if it did work out) compared to something along the lines of $110 shipped to the UK (not including import tax @20%).
Thanks for the reply though, might look into alternative 87s from China :)
Offline elton5354
« Reply #220 on: Thu, 27 March 2014, 14:52:30 »
You're better off buying one from this group buy
http://geekhack.org/index.php?topic=55555.0
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #221 on: Thu, 27 March 2014, 15:09:17 »
+1, I was thinking the same
x
Offline Stabilized
« Reply #222 on: Thu, 27 March 2014, 16:31:34 »
Fantastic, that is just what I was looking for! Thanks  :D
Offline JizzGus
« Reply #223 on: Thu, 27 March 2014, 18:17:44 »
placed an order for a gray top and bottom, though still unsure if that's the final colour i want.
Offline elton5354
« Reply #224 on: Thu, 27 March 2014, 19:41:55 »
You have a bit over 24 hours to decide on that. ;)
Offline CK Briefs
  • formerly calvins1
« Reply #225 on: Thu, 27 March 2014, 19:44:37 »
I think grey on grey is the most aesthetically neutral and goes well with any set imo.
Black is much too common and and the silver is very flakey-looking for me :S
I got grey top/bottom too :P In the end, it's your keyboard though
« Reply #226 on: Thu, 27 March 2014, 21:51:37 »
Have we see nvany pics of the gray?
Offline elton5354
« Reply #227 on: Thu, 27 March 2014, 21:57:27 »
Should be like the gray in the pictures like this one.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #228 on: Fri, 28 March 2014, 11:29:44 »
elton, any plans for doing a gb for the lightsaver v2? I'd be in for sure.
Offline elton5354
« Reply #229 on: Sat, 29 March 2014, 11:40:45 »
Probably in the near future...
Someone did an unboxing of their Orion...
http://kbdlab.co.kr/index.php?document_srl=160549&mid=board_Lsno50
« Last Edit: Sat, 29 March 2014, 12:29:59 by elton5354 »
Offline cultofjosh
« Reply #230 on: Sat, 29 March 2014, 12:37:40 »
While I ended up passing on this awesome group buy to invest in some high end soldering stuff, I seriously doubt I will be able to resist the lightsaver v2 one if you do it. I'm still upset that I missed the butterfly buy, I'll be keeping a close eye out for your future group buys :)
Offline ninjadoc
« Reply #231 on: Sat, 29 March 2014, 16:33:29 »
I'm fine in receiving my keyboard instead of via proxy.
Offline dragonken
« Reply #232 on: Sun, 30 March 2014, 10:53:45 »
elton,
Sent you a PM. Please check.
Regards,
dragonken
Offline yicaoyimu
« Reply #233 on: Sun, 30 March 2014, 11:06:03 »
Elton, do you know how I can get into Eagle group buy if no one wants to proxy?
Offline elton5354
« Reply #234 on: Sun, 30 March 2014, 11:22:35 »
I have no idea, but maybe I can run that too? ;)
Offline CK Briefs
  • formerly calvins1
« Reply #235 on: Sun, 30 March 2014, 11:30:08 »
Might as well RUN for prime minister at this point :P
So many gbs, you're too awesome haha
Offline nuclearsandwich
« Reply #236 on: Sun, 30 March 2014, 11:33:58 »
I may have to build and sell this Orion if the Viper and LightSaver v2 come too quick behind. Elton can you ask Duck to take a vacation?
« Reply #237 on: Sun, 30 March 2014, 11:36:50 »
I can't keep up with all these Duck boards. Viper, Eagle, Orion...
Edit: I see, they're 60%
« Last Edit: Sun, 30 March 2014, 11:39:27 by metalliqaz »
Offline yicaoyimu
« Reply #238 on: Sun, 30 March 2014, 11:43:36 »
Please please please! I checked the Viper thread and at least 6 members have expressed their interest.
Offline elton5354
« Reply #239 on: Sun, 30 March 2014, 12:45:46 »
Update on this group buy since it's closed now.  I forgot to withdraw the money from Paypal, so I did it just now.  I'll have to wait a couple days for the money to be in my account and then I can pay True Custom the money.  After that he will have them shipped in a week or 2.
Sorry for the delay.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #240 on: Sun, 30 March 2014, 16:40:40 »
Yes, Elton. Please?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #241 on: Sun, 30 March 2014, 16:54:29 »
What are these eagle and Viper group buys you people speak of? :P
EDIT: Found it
« Last Edit: Sun, 30 March 2014, 16:59:52 by JaccoW »
x
« Reply #242 on: Sun, 30 March 2014, 17:49:50 »
Yes, Elton. Please?
I'm also in favour of this.   :-*
Offline elton5354
« Reply #243 on: Sun, 30 March 2014, 17:51:12 »
I'm going to run it around May after Lightsaver V2 ;)
« Reply #244 on: Sun, 30 March 2014, 17:52:13 »
Any word on whether the V2 will come in more stock colors?
« Reply #245 on: Sun, 30 March 2014, 17:53:27 »
Mmmm, Lightsaver V2...  :)  Still disappointed I somehow missed out on the original run of that.  I hope I have money when you run V2...   :eek:
« Reply #246 on: Sun, 30 March 2014, 17:57:11 »
My favorite keyboard so far!  You won't regret it if you get it :D  So much fun to plan it out with all those options, from physical configuration to software.
« Reply #247 on: Sun, 30 March 2014, 17:59:54 »
Well your pictures are what made me regret missing it the most.  I unashamedly admit that if I could basically replicate what you've done I would be a happy camper.   :P
Offline elton5354
« Reply #248 on: Sun, 30 March 2014, 18:14:32 »
So far it's silver, black, and gray.  Any preference in any other colours? (Not that other colour options will happen, but maybe it will if enough interest?)
« Reply #249 on: Sun, 30 March 2014, 18:15:30 »
Pink :)
