Author Topic: Orion TKL Group Buy  (Read 841138 times)
Re: Orion TKL Group Buy
« Reply #500 on: Mon, 12 May 2014, 21:25:01 »
Turnaround time from me should be less than 3 business days too :P Monday is just by the latest. In fact, it's gonna be Victoria Day then so I'll get it out on Friday by the latest.
Offline cirrus82
« Reply #501 on: Tue, 13 May 2014, 00:18:43 »
Were we all supposed to get the acrylic pieces? Seems like some people received them but my package didn't seem to have them.
Regardless, fantastic package and product. Mine arrived and looks great! Seems like a very successful group buy. Well done!
Offline CK Briefs
  • formerly calvins1
« Reply #502 on: Tue, 13 May 2014, 00:19:38 »
Just for those who ordered grey :S
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline cirrus82
« Reply #503 on: Tue, 13 May 2014, 00:21:58 »
Your S face confuses me. Are you cereal?
Offline CK Briefs
  • formerly calvins1
« Reply #504 on: Tue, 13 May 2014, 00:23:14 »
It's a random face i use, yes im cereal
Offline cirrus82
« Reply #505 on: Tue, 13 May 2014, 00:25:51 »
Crap, I must've misread. Should've ordered grey! Very happy with mine, nonetheless.
« Reply #506 on: Tue, 13 May 2014, 15:53:38 »
IC for mini GB about to start...
Offline epzy
  • HHKB Fiend
  • ded
« Reply #507 on: Tue, 13 May 2014, 15:55:29 »
Really? AWESOME!
Offline CK Briefs
  • formerly calvins1
« Reply #508 on: Tue, 13 May 2014, 15:55:39 »
Lol it never hurts to grab more acrylic pieces right?
« Reply #509 on: Tue, 13 May 2014, 15:57:01 »
The problem is that they don't attach.  They just fill the space.  So if you pick up the keyboard, they stay on the table.  Does Duck intend for them to be glued?
Offline cirrus82
« Reply #510 on: Tue, 13 May 2014, 15:59:03 »
Can't remember where I saw this, but I think he intends for them to be stuck on with double sided tape.
I'm personally more interested in the acrylic plate that sits between the PCB and the bottom of the case, but would pitch in for both.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #511 on: Tue, 13 May 2014, 15:59:21 »
Double sided tape?
Offline CK Briefs
  • formerly calvins1
« Reply #512 on: Tue, 13 May 2014, 15:59:25 »
I thought that the pieces weren't held on only for viper etc.
If not, double sided tape is the solution
« Reply #513 on: Tue, 13 May 2014, 16:09:34 »
yes that's the only part I want as well.  ( I had gray so I got the consolatory inserts)
Offline cphead
« Reply #514 on: Tue, 13 May 2014, 17:35:25 »
I remember Elton had his attached with double sided tape. Not viable for moving around but good enough for when it's stationary. I'd be in for acrylic side pieces and the plate as well  :-*
« Reply #515 on: Tue, 13 May 2014, 20:16:17 »
Well, there's a problem.  The drawing files define a part that appears to be the correct shape, but is the wrong size.  They define a part that is about 4 inches long, and the Orion's insert is more like 3.25 inches long.  Not sure what's going on here.
The spacer plate would be $7.30 each (plus shipping to organizer, plus shipping) if we can get 5 takers.  Next tier would be 10.
Offline elton5354
« Reply #516 on: Tue, 13 May 2014, 20:17:56 »
Oh darn, might be because that's for the V1 style cases.  Let me see if I can get one for the V2 style.
Recommended way to stick your acrylic side inserts by Duck
http://duck0113.tistory.com/88
« Reply #517 on: Tue, 13 May 2014, 20:25:20 »
Thanks elton, you've been good to us.
If possible, DXF is better than DWG.  (It's open source compatible)
Offline elton5354
« Reply #518 on: Tue, 13 May 2014, 20:54:47 »
Here's the drawing for the side acrylic insert
http://kbdlab.co.kr/index.php?mid=board_tune&document_srl=153206
It is DXF file ;)
Offline CK Briefs
  • formerly calvins1
« Reply #519 on: Tue, 13 May 2014, 21:15:03 »
It is DXF file ;)
I need a pair of both styles (:
« Reply #520 on: Tue, 13 May 2014, 21:18:59 »
The DXF doesn't include any engraving.
Sound off boys.  Interest check form is online here.
« Last Edit: Tue, 13 May 2014, 21:20:44 by metalliqaz »
Offline CK Briefs
  • formerly calvins1
« Reply #521 on: Tue, 13 May 2014, 21:21:32 »
Wow, did not know the plate was also on the menu! Good surprise (:
« Reply #522 on: Tue, 13 May 2014, 21:26:30 »
Yeah, in case anyone doesn't know, it goes behind the PCB and spreads out the back-facing LED light around as an edge glow.
The plate at MOQ 5 is $7.30, plus organizer ship, plus taxes/fees, plus shipping.
The inserts at MOQ 10 are $3.99 ($8 for a set of two) plus all shipping/fees.
rough estimate is 1 kit to be about $20 plus shipping to you.
Offline elton5354
« Reply #523 on: Tue, 13 May 2014, 21:27:50 »
Damn that is expensive for the inserts :O
« Reply #524 on: Tue, 13 May 2014, 21:35:45 »
Indeed.  Small MOQs are a killer.  1000 pieces would be half that price.
5 or more $6.20
10 or more $3.99
50 or more $2.25
100 or more $2.11
1000 or more $1.99
Also Made-in-USA...
Note: if someone wants to do it in China, I'm perfectly willing to give it up.  To be honest it would save me a bunch of work.  Please only speak up if you've worked with a company before, though.  It would be a shame to tarnish this wonderful Orion project.
« Last Edit: Tue, 13 May 2014, 21:48:38 by metalliqaz »
Offline CK Briefs
  • formerly calvins1
« Reply #525 on: Tue, 13 May 2014, 21:58:05 »
I'm just wondering
But is there a chance we can have other colour acrylics if the interest is high enough? Although I'm not sure if there's such a thing as transparent/translucent coloured acrylic
« Reply #526 on: Tue, 13 May 2014, 22:16:22 »
Sure there is.  And BTW, the MOQ is actually 1 for everything, it's just that it's stupid expensive below the second tier.
EDIT: I'm wrong.  This guy only has clears and opaques.
« Last Edit: Tue, 13 May 2014, 22:18:34 by metalliqaz »
Offline CK Briefs
  • formerly calvins1
« Reply #527 on: Tue, 13 May 2014, 22:20:14 »
Oh I'd love to order a set of opaque alongside a set of clears :O
Count me in!
Offline nuclearsandwich
« Reply #528 on: Tue, 13 May 2014, 22:33:22 »
5 or more $6.20
10 or more $3.99
50 or more $2.25
100 or more $2.11
1000 or more $1.99
Also Made-in-USA...
elton, do you know if the insert sizes are the same for the Orion, Viper/Eagle, Lightsaver V2, and Butterfly? If so we might be able to get a better MOQ on the side inserts by breaking that out and offering it to everyone in those GBs as well. If the cutout sizes are all slightly different it's moot though.
« Reply #529 on: Tue, 13 May 2014, 22:35:28 »
5 or more $6.20
10 or more $3.99
50 or more $2.25
100 or more $2.11
1000 or more $1.99
Also Made-in-USA...
I was thinking the same thing.  My lightsaver v2 purchase could use some accompanying side inserts, and if they're all the same size I'd like to contribute to (and benefit from) this MOQ.
Offline elton5354
« Reply #530 on: Tue, 13 May 2014, 22:39:59 »
Probably not the Butterfly as they have the same style as V1's.
Let me check
Offline yicaoyimu
« Reply #531 on: Tue, 13 May 2014, 23:53:58 »
Finally.
Offline cphead
« Reply #532 on: Wed, 14 May 2014, 00:01:29 »
Finally.
Lookin' good. Is that a lock switch in the right alt position?
Here's potato pic of mine.
Looking all sad without side acrylic inserts.
Offline yicaoyimu
« Reply #533 on: Wed, 14 May 2014, 00:04:09 »
Finally.
You stole my idea! I was just about to post mine with Dolch on it. Yes it's a lock switch (with no actual practical sense but to look cool  :)) )
Offline cphead
« Reply #534 on: Wed, 14 May 2014, 00:45:11 »
Hehe  :p. It does look cool.
Offline yicaoyimu
« Reply #535 on: Wed, 14 May 2014, 01:39:01 »
OK, so here is the final version. WoB looks *amazing* on Orion. Even though my WoB set is shiny, I still love this combo. I will take better picture with sun light when I wake up.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #536 on: Wed, 14 May 2014, 01:46:41 »
I'd be fine with paying $20.
« Last Edit: Wed, 14 May 2014, 01:49:20 by epzy »
« Reply #537 on: Wed, 14 May 2014, 09:51:59 »
Now that it's finally here I can't decide: Tactile or clicky?  :-\
« Reply #538 on: Wed, 14 May 2014, 09:54:48 »
I'm trying to make that decision myself.  My favorite switch is MX brown, but I have a bunch of nice vintage blues handy that might be nice.
Offline GeeNDL82
« Reply #539 on: Wed, 14 May 2014, 09:58:46 »
clicky :P
So, anyone dont like your Orion, please PM to me  :'( >:D
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
Offline cirrus82
« Reply #540 on: Wed, 14 May 2014, 12:04:05 »
Looks like one of my SMD glow lights is toast.  Any one else have this problem?  I ordered two PCBs, the other one lights up all 4 (fortunately I tested before soldering).
Is there a good way to test if the problem is with the LED or the board?  Pretty new to this, I have a digital multimeter. If it's the LED, does anyone know exactly which kind and where I could order a replacement?  My soldering iron's tip is just small enough to fit around the LED, I might be able to get it off...  Not sure if I can get another back on there so cleanly, however.
EDIT:
Image posted upside down for some reason (looks straight on my machine), trying to fix it...
« Last Edit: Wed, 14 May 2014, 12:06:54 by cirrus82 »
« Reply #541 on: Wed, 14 May 2014, 18:13:45 »
How to bootloader?
Also someone please sell me theirs >_>
« Reply #542 on: Wed, 14 May 2014, 18:23:41 »
Oh my.  I can't wait to build mine.
I've decided to go with vintage blues from my busted Dolch and multi colored LEDs.
Does this board have different LED zones?
Offline CK Briefs
  • formerly calvins1
Orion TKL Group Buy
« Reply #543 on: Wed, 14 May 2014, 20:10:19 »
It does! Check duck0113's tistory for a  section on the different led modes
Offline Pacifist
  • on hiatus
« Reply #544 on: Wed, 14 May 2014, 20:17:11 »
How to bootloader?
Why not to assemble other people's keyboards: you don't get to keep them :'(
Offline elton5354
« Reply #545 on: Wed, 14 May 2014, 21:52:10 »
This is compatible chart for side windows.
LightPad = LightSaver V1
Orion
Viper = Eagle
LightSaver V2
That sucks. :(
Offline CK Briefs
  • formerly calvins1
« Reply #546 on: Wed, 14 May 2014, 22:00:03 »
Orion
Viper = Eagle
LightSaver V2
That sucks. :(
So are the conciliatory side windows that came with the grey colour orders of the Orion variety?
« Reply #547 on: Wed, 14 May 2014, 22:08:14 »
Orion
Viper = Eagle
LightSaver V2
That sucks. :(
Seems to fit from when I tried to put them on. Then realized I don't know how to actually put them on... so I put them back in the bag for you.
« Reply #548 on: Wed, 14 May 2014, 22:12:20 »
Thanks I found it.  Looks like there are 5 zones in the video:
F1: F1-F12
F2: num row, modifiers, and space
F3: alphas
F4: all right-side clusters
F5: backside LEDs
Caps and Scroll are obviously separate.  not sure what Esc does
« Reply #549 on: Wed, 14 May 2014, 22:13:10 »
Yes they fit the Orion, obviously.
