Author Topic: How to make a loose cap tighter?  (Read 2007 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Wed, 05 March 2014, 17:19:24 »
I just got my skull from eyesmiles :D And it fits kind of loosely over the stem. I've read about seran wraps, just don't have any.
« Last Edit: Wed, 05 March 2014, 17:21:22 by HUNTERANGEL121 »
  • Live long and prosper
Re: How to make a loose cap tighter?
« Reply #1 on: Wed, 05 March 2014, 17:20:10 »
Scotch tape, a very small piece placed over the stem on the switch. Place the cap over it and it should fit better.
And some advice, next time you have a simple question, put it in the simple questions thread.  :thumb:
« Last Edit: Wed, 05 March 2014, 17:22:53 by Computer-Lab in Basement »
tp thread is tp thread
Offline C5Allroad
« Reply #2 on: Wed, 05 March 2014, 17:23:15 »
Perfect! Thanks!
« Reply #3 on: Wed, 05 March 2014, 17:23:36 »
