Author Topic: "Poor man's" Dolch $50 + shipping or starting at $25 + shipping  (Read 2687 times)
Offline jacobolus
Re: "Poor man's" Dolch $50 + shipping or starting at $25 + shipping
« Reply #1 on: Fri, 07 March 2014, 02:36:36 »
If someone just wants the caps from this laptop, I have 2 sets from the same type of keyboard, one completely unused and one slightly used (a bit shiny, not too bad) I’ll happily sell either set (including the plate/pcb/stabilizers if you want) for much less than $25 (I got them from ebay, but I just wanted the switches). Shoot a PM.
« Last Edit: Fri, 07 March 2014, 02:40:41 by jacobolus »
« Reply #2 on: Fri, 07 March 2014, 03:15:16 »
I'd be tempted, but ...
1. Not all keycaps are standard shape, even "1!" is elongated.
2. The keycaps are lower profile, so any replacement or add-on "modern" Dolch sets would not match.
3. Too many missing keys e.g. only goes up to F10.
4. Space bar.
Offline PointyFox
« Reply #3 on: Fri, 07 March 2014, 03:25:48 »
Would be fun to bring that into Starbucks.
Offline Maxim
« Reply #4 on: Tue, 11 March 2014, 01:17:58 »
I've considered doing this with an IBM PC 5140.  And then complaining to the barista that the wi-fi doesn't work.
« Reply #5 on: Tue, 11 March 2014, 23:51:32 »
I will do this when I get my 40-lb selectric converted to USB (likely using small magnets and hall sensors on the typebars). I will then plug it into my phone for properly composing SMS messages.
Offline berserkfan
« Reply #6 on: Wed, 12 March 2014, 02:34:32 »
Let's see: your phone is 1/4 lb
The selectric is 40.
Your keyboard is 160x the weight of your phone?
To put it another way, I would be pretty impressed by the kind of guy who's hands are 160x the weight of his brain. My limited imagination supplies the figure of Mickey Mouse (who has huge hands and a pea sized brain).
« Reply #7 on: Wed, 12 March 2014, 07:48:31 »
it'll be on a table. I can't carry the typewriter and also type. It also needs to be plugged in to a wall to click correctly.
