Author Topic: KMAC Happy Modifications  (Read 3196 times)
Offline longweight
  • philanthropist
« on: Fri, 07 March 2014, 01:55:38 »
Hi all,
So I received my first ever KMAC yesterday and I love it! I'm not a huge fan of the red finish so I have a plan:
1. Remove Case
2. Desolder switches from plate (probably won't be me doing this)
3. Have plate and case stripped back to the raw material
4. Have a clear anodise applied
5. Rebuild (again not me)
6. Whack Scarface caps along with the Nostalgia set when that arrives
My question is, what is the KMAC Happy case made from? And is it CNC milled or cast?
Here is the starting point:
Re: KMAC Happy Modifications
« Reply #1 on: Fri, 07 March 2014, 02:14:02 »
It's milled aluminium. Not sure what grade.
« Last Edit: Fri, 07 March 2014, 02:19:19 by Photekq »
« Reply #2 on: Fri, 07 March 2014, 02:17:26 »
It's milled.
I don't think anyone has ever cast a case.  Not sure you'd want to cast a case either.
Offline longweight
  • philanthropist
« Reply #3 on: Fri, 07 March 2014, 02:26:30 »
Awesome thank you guys. I have found a local paint shop that is happy to strip and recoat for £10 :D
« Reply #4 on: Fri, 07 March 2014, 02:27:07 »
Bare in mind that it's anodised, not painted. Make sure they don't try to strip the paint off it..
Offline longweight
  • philanthropist
« Reply #5 on: Fri, 07 March 2014, 02:30:45 »
I know and they can do that, I couldn't think of the correct word for them, anodising shop?
« Reply #6 on: Fri, 07 March 2014, 02:31:38 »
Ah right, that's good. I believe anodising shop is the correct term ;D Let us know how it goes - I need a decent anodiser in the UK.
Offline longweight
  • philanthropist
« Reply #7 on: Fri, 07 March 2014, 02:47:22 »
I will, the guy seemed a bit confused at first but I should be going down to see him next Friday if everything goes to plan.
Just got to decide on the colour!
