Author Topic: Has any manufacturer tried this?  (Read 3587 times)
Offline Kamen Rider Blade
« on: Fri, 07 March 2014, 04:01:48 »
Since Pad Printing is the most common / cheapest method to print a keycap on standard keyboards, have the manufacturers ever thought about adding in a thin clear polycarbonate layer see through plastic layer on top that snaps into place through side holes on the keycap itself?
The Polycarbonate layer would effectively take all the day to day wear while the pad printing itself will remain.
The Polycarbonate layer only needs to be 1 mm thick and standardized on keycap size.
You don't need to protect the front side of a keycap's screen printing for Fn key function labels since they never get touched through regular usage.
Any thoughts from the GH crowd?
Offline tbc
Re: Has any manufacturer tried this?
« Reply #1 on: Fri, 07 March 2014, 04:14:55 »
Sounds  insanely expensive
« Reply #2 on: Fri, 07 March 2014, 07:22:31 »
Sounds like clear caps on IBM buckling springs, with legends on the stem piece.
- D Trump 2026-10-24
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Fri, 07 March 2014, 08:48:01 »
Yes these exist. You have described relegendables. While blank relegendable may be more common, there are some keyboard that have pad print or lasered legend to follow standard layout under the lens in cases where alternate programming may not be needed.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #4 on: Fri, 07 March 2014, 08:53:40 »
aaaaaaaaaaand they look like ****
« Reply #5 on: Fri, 07 March 2014, 10:08:23 »
Nice!  How are these keycaps?
« Reply #6 on: Fri, 07 March 2014, 10:27:27 »
Is there anyway to mass produce these to be cheap?
« Reply #7 on: Fri, 07 March 2014, 11:46:32 »
I don't care for the feeling of polycarb... but I guess they are OK for the purpose they serve. They aren't expensive. You can buy 250 sack of them from many POS equipment place on internet for like $35 or so. Downside is they only come in top row profile, and 1x1, 1x2 and 2x2 size only.
Offline mougrim
« Reply #8 on: Fri, 07 March 2014, 13:08:07 »
Too glossy. Must be a hell to type in a bright light.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Fri, 07 March 2014, 13:09:18 »
To smooth.  I gotta have texture to the caps.
Offline mougrim
« Reply #10 on: Fri, 07 March 2014, 13:25:33 »
Too glossy, too smooth... no good, to be short.
Offline Pacifist
  • on hiatus
« Reply #11 on: Fri, 07 March 2014, 13:36:24 »
don't use them, barely anybody likes to type on them
also for me they fall off often
Offline mougrim
« Reply #12 on: Fri, 07 March 2014, 13:45:07 »
Well, probably 9 of 10 users of those keys are those poor sods who are HAVE to use them. Because they are working behind the counter in some shop.
Offline berserkfan
« Reply #13 on: Fri, 07 March 2014, 15:41:26 »
As a guy who Does use relegendables, I agree. Buy them if you need them. Don't buy them if you don't have layers that you need to label. They are not fun to type on.
« Reply #14 on: Fri, 07 March 2014, 15:48:50 »
They're really lame. They feel alright, but they're rattle-y.
Offline PhineasRex
« Reply #15 on: Fri, 07 March 2014, 18:19:09 »
The only ones I have tried are profileless and totally flat, which I did not like.
