Author Topic: keycaps: tampoprinted vs lasered?  (Read 3713 times)
Offline ozar
« on: Mon, 23 March 2009, 14:57:38 »
Hoping one of you might know the answer to this.  I think that I understand the difference in the two processes, but is one process better or more desirable than the other?
I only discovered the tampoprint process earlier today, so don't really know that much about it, or how to compare the two processes just yet.
Thanks to anyone that knows about these procedures.
Offline lam47
« Reply #1 on: Mon, 23 March 2009, 15:48:38 »
Dual injection ;)
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline itlnstln
« Reply #2 on: Mon, 23 March 2009, 15:55:08 »
Quote from: lam47;25145
Dual injection ;)
Dual Injection Molded FTW.  Laser printed aren't bad either, but DIM as a better quality look and feel, IMO.
Offline ozar
« Reply #3 on: Mon, 23 March 2009, 15:57:48 »
Sandy posted a bit about keycaps and dual injection here, but I'm still a bit confused about all this and the different processes.  I know that many of Cherry's keyboards had the tampoprinted keycaps, while others used lasered.
What was the process used for the old IBM Model M keycaps?  That lettering seems to never rub off regardless of the amount of typing done on them.
Offline itlnstln
« Reply #4 on: Mon, 23 March 2009, 16:11:33 »
If I am not mistaken, they are dual injection molded.  DIM works by creating a keycap with a "hole" where the legend is, then pressing a different color plastic into the "hole."  This, IMO, gives the keys a very professional, clean finish that laser can't match (silk screening can, but it has a tendency to rub off).
IMO: DIM > Laser > Silk Screen
Offline Chloe
  • Switch Kitten
« Reply #5 on: Mon, 23 March 2009, 16:34:41 »
You can read a bit more about keycap technology:
http://translate.google.com/translate?hl=en&sl=cn&u=http://blog.dengzhe.com/article.asp?id=253
http://park16.wakwak.com/~ex4/kb/tech_mold.htm
http://park16.wakwak.com/~ex4/kb/tech_laser.htm
http://park16.wakwak.com/~ex4/kb/tech_sublimation_print.htm
Cherry tampoprinted wear quite quickly, but I think they look better for black keycaps than recent lasered. I generally prefer lasered or dye sublimated PBT.
Offline ozar
« Reply #6 on: Mon, 23 March 2009, 16:38:32 »
Thanks, Chloe... that looks like it should explain it well.
I really like the looks of that keycap in the 2nd link.
Edit:  That 1st link is full of good info, too, although it takes a bit of concentration even after translation.  ;)
Offline Etinin
« Reply #7 on: Tue, 24 March 2009, 20:41:20 »
Anyone knows what process does Unicomp use for their keycaps?
Unicomp SpaceSaver (white)
Only good keyboard due to high shipping costs and import taxes but loving it so far.
