Author Topic: IBM SSK II  (Read 4096 times)
Offline irendulic
IBM SSK II
« on: Fri, 07 March 2014, 19:21:31 »
Hello,
if there are any other IBM SSK II rubber dome fans out there, here's a nice deal, 48$ shipped brand new ones.
http://www.ebay.com/itm/NEW-IBM-SPACE-SAVER-SPACESAVER-II-BLACK-KEYBOARD-WITH-DRIVER-CD-/141212239481?pt=PCA_Mice_Trackballs&hash=item20e0e7c679
Offline berserkfan
Re: IBM SSK II
« Reply #1 on: Fri, 07 March 2014, 19:56:12 »
excellent!
I believe someone was looking for just this a while back. It may be a rubber dome, but it's no cheapo low end rubber dome.
Offline dgreekstallion
  • B.S. Fiend
Re: IBM SSK II
« Reply #2 on: Fri, 07 March 2014, 19:59:37 »
I wonder how hard it would be to take it apart and modify it to a buckling spring variant...
Recent keyboard fanatic.
Model F-122 convert.
Offline esoomenona
  • Gnillort?
Re: IBM SSK II
« Reply #3 on: Fri, 07 March 2014, 22:05:46 »
It'd probably be much easier to buy a black M13, and mod it to a TKL with a Trackpoint. One day, I'll do this to my own.
Re: IBM SSK II
« Reply #4 on: Fri, 07 March 2014, 22:06:53 »
basically impossible
These use scissor switches, so you'd need a new case (taller for BS switches), new keycaps, new springs/hammers. I guess you could re-use most of the matrix and controller, but there's not really a point since fabricating the rest is hard / expensive.
It would be easier to build a BS keyboard from the ground up.
Or mod a SSK or AT model F (or F122) to add a trackpoint.
« Last Edit: Fri, 07 March 2014, 22:09:48 by dorkvader »
Offline ZeDestructor
Re: IBM SSK II
« Reply #5 on: Fri, 07 March 2014, 23:31:42 »
Is there a guide/thread on that mod?
I have some F122s inbound..... and trackpoint would be perfection!
Offline Pacifist
  • on hiatus
Re: IBM SSK II
« Reply #6 on: Fri, 07 March 2014, 23:35:56 »
F122 inbound from where???
Re: IBM SSK II
« Reply #7 on: Sat, 08 March 2014, 09:21:20 »
The last one you posted. It's only slightly more than what I paid for my Year of the Tiger Ducky with an extra set of caps back in 2011.
Offline ed_avis
Re: IBM SSK II
« Reply #8 on: Mon, 10 March 2014, 04:46:07 »
Don't forget the predecessor of this keyboard, which is not the buckling spring Model M, but the buckling rubber sleve M4-1.
Offline sethstorm
Re: IBM SSK II
« Reply #9 on: Sat, 15 March 2014, 00:46:07 »
(a bit OT, but...)
Haven't made one, but I could if you wish.
The short of it is:
Obtained keys from an M13 (black or white will do)
Redid the keyboard to ANSI layout
Obtained a trackstick assembly from an EnduraPro
Shaved down the B key to fit the stick (to get rid of the overhang)
Installed the stick, fastening it between barrels with extra-stick (3M VHB) tape
Put the controller in the far upper right
Removed DIP switch slot, feeding usb cable through that
« Last Edit: Sat, 15 March 2014, 00:49:42 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
