Author Topic: Caps Lock key with LED window?  (Read 3454 times)
Offline swornxin
    • Nailed Down Custom Pins
« on: Fri, 07 March 2014, 19:21:57 »
I just ordered a set of keys for my QFR from WASD, and I'm now realizing that it the set doesn't come with a windowed caps lock key for the LED underneath.  Does anyone know where I can grab something like that alone?  I've looked for them in all of the sellers from this forum.  I'd also be okay with a semi-translucent keycap as it would still allow me to see that caps lock was on.
Thanks in advance.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline mougrim
Re: Caps Lock key with LED window?
« Reply #1 on: Sat, 08 March 2014, 03:47:16 »
Hmmm.... Maybe you can just, you know... cut window for the led yourself?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #2 on: Sat, 08 March 2014, 09:59:48 »
You can drill a very small hole in the keycap for the LED, and (optionally) fill the hole from the backside with clear epoxy.
A few of us have done that and it looks fine.  Search for the thread; I and a couple of others posted how-to guides.
 - Ron | samwisekoi
p.s.  I mean very small.  1mm or 1/16".  Otherwise you will have an LED shining a beam straight into your optic nerve.  Ouch!  Such pain.  So need a small hole!
Offline mougrim
« Reply #3 on: Sat, 08 March 2014, 10:10:19 »
 - Ron | samwisekoi
Yep. That what i meant. And yes, small holes are the best... in this case and many others :)
Offline swornxin
« Reply #4 on: Sat, 08 March 2014, 10:27:23 »
I may try it with one of my older keys first.  Maybe with the stock QFR cap that has awful font on it.   :))
Thanks for the info!
Offline mougrim
« Reply #5 on: Sat, 08 March 2014, 11:15:51 »
That's the point of it. Practice on something you can allow to destroy :)
