Author Topic: WASD Keyboards UV Printing  (Read 5173 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Sat, 08 March 2014, 13:20:28 »
https://www.facebook.com/wasdkeyboards/posts/675687842470222
I saw this the other day on their facebook page.  Seems like a pretty cool idea because now you can literally go with any design and any color.
Obviously it won't be as nice as PBT dye sub but I think otherwise it's a good start and opens up different possibilities.
I noticed the color look a bit faded on the color art ones but on just small symbols I think it works fine.
Hopefully the durability will be ok.
Re: WASD Keyboards UV Printing
« Reply #1 on: Sat, 08 March 2014, 18:40:09 »
It can actually look better than dyesub PBT given the right background since the fidelity is higher.  Depending on the printer they use, some are close to 6000DPI.  The way QWERKeys/Sleabo does it doesn't result in the best look on dark keys (wish I knew that before), but there are ways of making it look good even on dark caps.
It's also quick, easy, and fairly cheap to do, probably cheaper than their laser:
Odds are they just have a little jig they drop the set in, an acrylic/wood/metal/whatever mask they set on top of that, then they just print the full image.
It's cool, but I really wish they would work on getting a better cap supplier before doing gimmicky stuff like that.  They're so bad that I'd rather have OEM caps than WASD caps.
Offline Hyde
« Reply #2 on: Mon, 10 March 2014, 00:16:16 »
Ohhhhhh those video look pretty cool !  Thanks for the link and explaination.
Lol and what's wrong with WASD keycaps?  I thought they're made by Costar no?
Also I think if this turns out well it would fix the issue of dye sub can only do darker color.
Would be a cheaper / better choice for more custom legend / graphic.
:D
« Reply #3 on: Mon, 10 March 2014, 00:18:44 »
Their caps are just so thin and flimsy.  They really are not fun to use.
Offline dreydin
« Reply #4 on: Mon, 10 March 2014, 01:54:45 »
About the WASD keycap quality, this is good to know. Thanks!
Offline Hyde
« Reply #5 on: Mon, 10 March 2014, 09:10:29 »
But isn't that just about the same for any OEM stock ABS keycaps?  Unless you get a Poker II or Ducky G2 Pro then it comes with stock thick PBT.
So I always thought they're just "on-par" with other ABS stock keycaps.
:P
« Reply #6 on: Mon, 10 March 2014, 09:22:53 »
I actually feel that they're worse than most OEM caps.
Offline RESPRiT
  • HHKB = ❤
« Reply #7 on: Mon, 10 March 2014, 09:33:54 »
I think WASD definitely scraps quality for customization, but for new users it seems to work out pretty well since they don't know what they're missing yet :P
