Author Topic: Japanese IBM on uk ebay  (Read 8008 times)
Offline lam47
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline lowpoly
« Reply #1 on: Tue, 24 March 2009, 09:15:47 »
Thanks.
Offline lam47
« Reply #2 on: Tue, 24 March 2009, 09:19:19 »
I have asked him what the model number is as its not quite the same as mine.
However there are a few versions of this board.
Will post if I hear back.
I wont be bidding as I have one :) (thanks Sandy)
Offline sandy55
« Reply #3 on: Tue, 24 March 2009, 10:52:33 »
Yours is p/n 79F0167.  No model number is printed on the label but it is called as "5576-A01" with  buckling spring switches over membrane.
The one on eBay is 5576-B01, conductive rubber over membrane. made by Mitsuimi.  Quality of plastic is rather bad and easy to get yellowed.
Offline Mercen_505
« Reply #4 on: Tue, 24 March 2009, 18:02:20 »
Thanks, Sandy! I was wondering if the picture had just turned out weird or if the plastic was starting to turn yellow.
Offline MANISH7
« Reply #5 on: Tue, 24 March 2009, 18:55:56 »
For you guys who use Japanese keyboards...is the really small space bar a problem? Even on the standard size spacebar, I hit the very end of it. Make it any shorter and I'd be uncomfortable in reaching it. Of course, I keep my hands far apart to begin with (in an ergonomic position) so it may be just me.
Offline lam47
« Reply #6 on: Wed, 25 March 2009, 06:55:19 »
If you are on the home row. As in index on right hand on the J you should have no problem unless you have a very short thumb. I dont have to adapt at all to reach it.
The tiny BS is an issue for me so I use the key to the left of the space bar with my left thumb. I would not use a Jap layout all day.
Offline lam47
« Reply #7 on: Wed, 25 March 2009, 07:17:45 »
double post sorry
Offline MANISH7
« Reply #8 on: Wed, 25 March 2009, 09:19:34 »
Quote from: lam47;25363
Thanks for the response. Yeah, that is true. Too bad I'm used to hitting the spacebar with my left thumb instead of the right thumb.
Offline lam47
« Reply #9 on: Wed, 25 March 2009, 12:16:02 »
I see. You may have a bit more trouble then.
Sorry.
Offline lowpoly
« Reply #10 on: Wed, 25 March 2009, 12:43:36 »
Quote from: sandy55;25250
LOL, someone overbid me please. :)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #11 on: Wed, 25 March 2009, 23:40:07 »
Quote from: lowpoly;25420
:) I've been there, buddy.
Offline lowpoly
« Reply #12 on: Thu, 26 March 2009, 02:21:45 »
Offline Chloe
  • Switch Kitten
« Reply #13 on: Thu, 26 March 2009, 05:43:56 »
lowpoly, you can retract your bid:
http://pages.ebay.com/help/buy/bid-retract.html
Quote from: MANISH7;25313
I don't have a problem with the smaller space bar. I usually hit it around the V and B key with my left thumb. My only issue with Japanese layout is the placement of backslash/pipe next to right Shift instead of left Shift (UK layout). I don't mind the smaller Backspace either.
Offline lam47
« Reply #14 on: Thu, 26 March 2009, 05:46:14 »
Do you have laser guided fingers?
Offline lowpoly
« Reply #15 on: Thu, 26 March 2009, 05:58:01 »
Quote from: Chloe;25521
Thanks. It doesn't really apply here, I guess. I'll just man up to my mistake. :) I only bid the minimum amount so there's still hope.
Offline lowpoly
« Reply #16 on: Thu, 02 April 2009, 09:58:12 »
F*ck, I won it, lol.
Offline chimera15
« Reply #17 on: Wed, 29 April 2009, 15:36:54 »
Quote from: Chloe;82117
Yeah, it's not the spacebar that's usually the problem.  For me it's that the " gets transferred under the 2 key and lots of punctuation keys get shifted around in particular modes.  If you're typing in Japanese you almost never use space, so that's why the spacebar isn't that important.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
« Reply #18 on: Wed, 29 April 2009, 15:38:33 »
Quote from: lowpoly;83235
I always feel that way when I win an auction. roflol  It has rubber domes?
Alps boards:
Offline lowpoly
« Reply #19 on: Wed, 29 April 2009, 16:25:56 »
I never pulled a cap. Can do that tomorrow.
I wish I had xsphat's strength and could just throw it away.
Offline itlnstln
« Reply #20 on: Wed, 29 April 2009, 16:34:58 »
If it has domes, I can find the strength to throw it away. If it were mechanical, it would be harder, though. I would keep it in case I needed the parts for something.
Offline lowpoly
« Reply #21 on: Thu, 30 April 2009, 03:50:48 »
It has those rubber sleeves.
First pic on this page.
Edit: That page seems to be a mod where someone converts the sleeves to springs. Might work with M4s (?) as well.
« Last Edit: Thu, 30 April 2009, 04:18:35 by lowpoly »
