Author Topic: cleaning ibm keycaps  (Read 4065 times)
Offline qnaal
« on: Sun, 09 March 2014, 16:22:52 »
I've got an XT F and also a model M- I'm about to go up to the store and grab some denture tabs to clean the keycaps, but I was wondering about the material used in the keys- are they all BPT, meaning I don't have to worry too much about heat for drying them?
I was leaning toward the pillowcase-in-the-drier method, but if I gotta be extra careful with the spacebars or something...
Offline Pacifist
  • on hiatus
Re: cleaning ibm keycaps
« Reply #1 on: Sun, 09 March 2014, 16:31:56 »
just pull of keys, put in dishwasher, then denture tablet, and they are clean
Offline qnaal
« Reply #2 on: Sun, 09 March 2014, 16:35:12 »
I don't have a dishwasher... should I let them sit in some detergent before using the tabs?
They aren't very dirty, I just want to freshen them up a bit
Offline Pacifist
  • on hiatus
« Reply #3 on: Sun, 09 March 2014, 17:20:09 »
freshen up just use denture
Offline strafe
    • Strafe's Blog
« Reply #4 on: Sun, 09 March 2014, 17:40:19 »
I've cleaned a couple of Model M's in the last few weeks, 2 litres of warm water and 2 denture tabs works well for one set of keycaps.
« Last Edit: Sun, 09 March 2014, 17:42:48 by strafe »
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline qnaal
« Reply #5 on: Sun, 09 March 2014, 18:12:37 »
And I'm getting the idea that these spacebars just don't come off?
I'm fine with that, though I might try to lighten the one on the XT in the future...
« Reply #6 on: Sun, 09 March 2014, 18:39:21 »
Sure, XT spacebars come off. They just don't go back on without a lot of heartache.
- D Trump 2026-10-24
« Reply #7 on: Sun, 09 March 2014, 19:34:50 »
I used 3 denture tabs in warm water for my two sets of Model M keycaps.
And I spread them out on newspaper and just let them dry naturally over a few days.
Offline qnaal
« Reply #8 on: Sun, 09 March 2014, 20:15:26 »
I threw the keytops to my model M (which were already pretty clean but why not) and the XT keycaps in a big bowl with 4 tabs (perhaps overkill?), and filled it with hot water from the tap.
Some of the XT keys had the yellow/brown layer on them, and they cleaned right up.
I rinsed them, and tossed them in a pillowcase, and tossed the pillowcase in the drier on delicate for a while- I worried that the smacking around at high temperatures might damage the stems, so I wrapped the pillowcase in a towel for buffering.
MINTY FRESH
I got a box of 40 tabs for $4 at the convenience store up the street, so I'll have to try it again the next time I want to gently clean a ****ton of tiny pieces of something :\
« Reply #9 on: Sun, 09 March 2014, 22:32:17 »
That's one thing about denture tabs - they are cheap.
So you can buy a box and use 2 or 3 or even 4 to clean, try again if you like, and if they are still dirty, try something else.
Also you can use an old toothbrush to scrub any stubborn dirt off.
Offline berserkfan
« Reply #10 on: Sun, 09 March 2014, 23:51:55 »
DO NOT even think of pulling off the XT's spacebar. Unless you are a damn expert modder. I wasted like meters of dental floss trying to put back my spacebars. Those modders make it sound easy, and it's NOT.
Offline jacobolus
« Reply #11 on: Wed, 12 March 2014, 03:13:10 »
To clean keycaps, I put them in a bowl of water with a bit of dish soap, and swirl them around a bit. Then I swap out the water and add a few denture tabs, and leave it 4+ hours. Then I swap out the water again and add a tiny bit of dish soap again, which takes the denture tab residue off better than straight water. Then I rinse in water a couple of times. If there are any remaining dirty spots, a quick swipe with a sponge or scrubber should fix it. Then I just leave them to try on a towel for a day or two.
Overall, it only takes about 3 minutes of active effort, plus a bunch of waiting in between.
So far this has worked perfectly for a few sets of *extremely* greasy dirty gross keycaps.
« Last Edit: Wed, 12 March 2014, 03:15:44 by jacobolus »
« Reply #12 on: Wed, 12 March 2014, 06:51:39 »
The entire process is easily accomplished in 20-30 minutes of active work.
Use a spoonful of powdered laundry detergent and a quarter spoonful of "Oxi-Clean" in a liter of hot water for 5-10 minutes.
Rinse thoroughly at least 3 times by filling the bowl with hot water and dumping them through a colander.
Lay a T-shirt out on the bed and sling the water out of each cap by hand, toss it aside. When I finish, I turn them face up on 2nd dry T-shirt and they dry in 10 minutes.
