Author Topic: Cherry MX White (not Clear)  (Read 4094 times)
Offline morpheus
« on: Mon, 10 March 2014, 01:02:23 »
Can anyone please direct me to the place where I can buy individual Cherry MX White switches? I want to test them out.
Thanks
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Cherry MX White (not Clear)
« Reply #1 on: Mon, 10 March 2014, 03:12:42 »
Thanks
I believe Qwerkeys had one in their switch tester. At least mine did.
I might still have one from there and one from MrInterface's GB.
|||My other keyboards :
x
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Mon, 10 March 2014, 05:08:50 »
7bit has plate-mount whites in stock.
« Reply #3 on: Mon, 10 March 2014, 07:07:13 »
Thanks
How many do you need?
Offline berserkfan
« Reply #4 on: Mon, 10 March 2014, 07:19:26 »
Thanks
HA! Thought you sold me all of yours already!
« Reply #5 on: Mon, 10 March 2014, 07:27:04 »
Thanks
I think I have a few I bought from 7bit, somewhere.
Offline morpheus
« Reply #6 on: Mon, 10 March 2014, 09:14:00 »
Thanks
Just one, maybe two.
« Reply #7 on: Mon, 10 March 2014, 09:27:04 »
Thanks
I think I can help you with that, I'll have to double check but I'm fairly certain I had a few from 7bit left, just need to find them.
Offline morpheus
« Reply #8 on: Mon, 10 March 2014, 12:10:14 »
Thanks
Ok, thanks, let me know if you find them  :thumb:
Offline simon_C
« Reply #9 on: Mon, 10 March 2014, 14:27:00 »
cant you just create whites by putting a different spring in blues?
Offline davkol
« Reply #10 on: Mon, 10 March 2014, 16:03:02 »
Nope. There's a difference in the stem or lubing. I've seen either hypothesis "confirmed" (don't ask me for links though).
Offline Moosecraft
  • HHKB Pro
« Reply #11 on: Mon, 10 March 2014, 16:14:42 »
Cherry's AMA said there was not any different lubing on whites if I recall correctly.
« Reply #12 on: Mon, 10 March 2014, 16:17:40 »
I still don't believe it :P
Offline Techno Trousers
  • ʘ_ಠ
« Reply #13 on: Mon, 10 March 2014, 16:40:47 »
According to deskthority, the modern whites you'd be (theoretically) able to buy new would be functionally identical to MX green. Older whites are either very similar to blues or greens, depending on the age. It's a very perplexing switch to me. And the visual confusion with MX clear makes it that much worse.
« Reply #14 on: Mon, 10 March 2014, 16:41:46 »
mx white's feel and sound different than mx greens
« Last Edit: Mon, 10 March 2014, 16:51:48 by SpAmRaY »
  • ʘ_ಠ
« Reply #15 on: Mon, 10 March 2014, 17:02:43 »
Are they closer to blues?
« Reply #16 on: Mon, 10 March 2014, 17:07:04 »
They are definitely quieter than blues but lighter I'm not so sure, I didn't do a direct comparision, I mainly tried whites and greens side by side, blues I haven't really used much at all.
Offline Charizard^
« Reply #17 on: Mon, 10 March 2014, 17:40:11 »
You can still get them via deskthority if you dont mind paying the cost and shipping fee.
http://deskthority.net/marketplace-f11/cherry-mx-taking-pre-orders-t2760.html
Offline QuadGMoto
« Reply #18 on: Mon, 10 March 2014, 18:20:15 »
I recently used the stacked nickels test to compare the activation weight needed for a bunch of MXs. The blue and brown switches were the lightest at 11 nickels. Next was the "ergo" clear at 12, the stock clear (and salmon Alps on my AEK) at 14, the green at 15, with the white coming in the heaviest at 16.
All of the Cherrys were not lubed (by me) or broken in. The Alps had been used for years before being retired.
