Author Topic: G81 with Black Doubleshots $35 + shipping, make offer  (Read 6688 times)
Offline bazh
Re: G81 with Black Doubleshots $35 + shipping, make offer
« Reply #1 on: Mon, 10 March 2014, 23:58:46 »
shipping $390.62 (approx. 8,311,063.83 VND)
wow :))
btw, that is helvetica legend, so it must be pad printed, not doubleshot
HHKB Pro2 white
Newbie again
Offline ebacho
« Reply #2 on: Tue, 11 March 2014, 00:00:47 »
If you're looking for a set of these, this seller has new ones and accepts offers of $30 USD (or did when I go mine off him)
http://www.ebay.com/itm/CHERRY-G81-7000HUBUS-2-Compact-104-Key-43-Progr-Keys-2-Track-MSR-2-Usb-Port-/350572017058?pt=PCA_Mice_Trackballs&hash=item519fb875a2
« Reply #3 on: Tue, 11 March 2014, 00:00:58 »
Could be then. I was just going off the model numbers.
Offline Pacifist
  • on hiatus
« Reply #4 on: Tue, 11 March 2014, 00:04:38 »
Are these doubleshots?
Offline ebacho
« Reply #5 on: Tue, 11 March 2014, 00:05:09 »
« Reply #6 on: Tue, 11 March 2014, 00:07:35 »
They've got scoops and the model starts with an H, so it should be.
Offline Pacifist
  • on hiatus
« Reply #7 on: Tue, 11 March 2014, 00:08:17 »
These definitely are.
Yup, compared with my shiny DS set, best way IMO is the position of the ^ on the 6 key, if its really low hanging its a DS, otherwise its other type.
Also after looking at many many g81s, I belive G81 numbers are hit or miss. A lot of times there's H in the number but its lasered POM...
Offline ebacho
« Reply #8 on: Tue, 11 March 2014, 00:10:22 »
Shift legends are also thicker.  G81 numbers are pretty good usually, at least in relation to keycaps.  I personally think its the seller getting large lots of these keyboards and picking one label to photograph without looking at all of them, leading to mismatches like in nubbinator's OP.
Offline bazh
« Reply #9 on: Tue, 11 March 2014, 00:13:24 »
I always first look at the G legend, you know it's Cherry DS if there're no little tail on it :D  Also notice the thickness of the legend too
« Last Edit: Tue, 11 March 2014, 00:15:30 by bazh »
HHKB Pro2 white
Newbie again
Offline Pacifist
  • on hiatus
« Reply #10 on: Tue, 11 March 2014, 00:16:02 »
It happens more than you think. its pretty annoying when you're looking for a set of doubleshots and everything is POM
Offline ebacho
« Reply #11 on: Tue, 11 March 2014, 00:17:02 »
At least now you have a few good tips to identify them by sight  :p
Offline Pacifist
  • on hiatus
« Reply #12 on: Tue, 11 March 2014, 00:20:05 »
Yea :p Having a set in front of you helps a lot, but even still, I never noticed the stem on the G key. The more you know
Offline Maxim
« Reply #13 on: Tue, 11 March 2014, 01:08:05 »
What I've noticed:
The pad/laser ~ is smaller than the doubleshot ~.  The doubleshot tilde is about half the width of the cap.
Prt Sc / Sys Rq and Pause / Break are on the same plane on pad/laser Cherry caps, while doubleshot Cherry caps have Sys Rq and Break on the fronts of the caps.
My guess is that the keyboard in the first post is a G81-HPBUS-2 that was sent in for refurbishing.  This resulted in the shiny caps being replaced with laser-etched caps.  What's strange, though, is that in the picture near the bottom of the listing is a keyboard that very likely is an intact G81-HPBUS-2.  Just a guess, but it's probably the kind of thing where they have a large stock of these keyboards in various states of wear.
Offline jacobolus
« Reply #14 on: Tue, 11 March 2014, 02:46:39 »
When in doubt, 'ask a question' of the seller, requesting that they confirm that the picture matches what they're going to send you, and confirm the model number from the back. Often they're like "yep, it's not the same model number as listed in the ad. sorry." – of course, they then don’t bother to change the ad title / text; pretty irresponsible, but whatever.
« Reply #15 on: Tue, 11 March 2014, 23:54:19 »
You can have scoops on lasered POM.
Offline Pacifist
  • on hiatus
« Reply #16 on: Tue, 11 March 2014, 23:56:01 »
I think a lot of boards were sent back to cherry to get refurbed and cherry put on POMs instead of DS keys resulting in incorrect #s
Offline Charizard^
« Reply #17 on: Wed, 12 March 2014, 23:03:31 »
These are GMK right?
Offline Pacifist
  • on hiatus
« Reply #18 on: Wed, 12 March 2014, 23:05:47 »
« Reply #19 on: Wed, 12 March 2014, 23:08:20 »
No.
They should be original cherry.
Offline Charizard^
« Reply #20 on: Wed, 12 March 2014, 23:08:45 »
Is POM the material or profile?
Offline Pacifist
  • on hiatus
« Reply #21 on: Wed, 12 March 2014, 23:09:40 »
material
cherry is always cherry profile
Offline Charizard^
« Reply #22 on: Wed, 12 March 2014, 23:12:18 »
Is GMK a modern cherry profile then?
Offline Pacifist
  • on hiatus
« Reply #23 on: Wed, 12 March 2014, 23:13:04 »
gmk bought cherry hardware to make caps
Offline Charizard^
« Reply #24 on: Wed, 12 March 2014, 23:14:13 »
Ok thanks!
Offline Flyersfan1
  • Hi!
« Reply #25 on: Thu, 13 March 2014, 11:59:57 »
I'm quite sorry if this is a dumb question, but those caps would be comparable with the ones you'd get through GMK today, right? It's only some of the bottom row caps and modifiers that wouldn't be compatible with more modern layouts today?
Quote from: Photekq
« Reply #26 on: Thu, 13 March 2014, 12:02:59 »
Correct and depending on how 'used' these are some keys will be very shiny and the keys on the right side will have a slightly different profile than what you might expect due to the layout being different.
« Reply #27 on: Thu, 13 March 2014, 12:06:30 »
For these boards the answer is NO. They are NOT doubleshot. : http://www.ebay.com/itm/Cherry-MultiBoard-Keyboard-G81-7000-G81-7000HPBUS-2-with-Card-Reader-/200824157908?pt=LH_DefaultDomain_0&hash=item2ec20d76d4
For these boards the answer is yes. They ARE doubleshot : http://www.ebay.com/itm/CHERRY-G81-7000HUBUS-2-Compact-104-Key-43-Progr-Keys-2-Track-MSR-2-Usb-Port-/350572017058?pt=PCA_Mice_Trackballs&hash=item519fb875a2
Offline mougrim
« Reply #28 on: Fri, 14 March 2014, 06:45:52 »
wow :))
Fukken 600 USD for me. Seller is a loonie :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Candyflip
« Reply #29 on: Fri, 14 March 2014, 07:02:44 »
Shipping: $662.45 UPS Worldwide Saver. It's definitely a SAVER!
Offline ZeDestructor
« Reply #30 on: Fri, 14 March 2014, 07:29:36 »
As always, talk to the guy... I almost pulled the trigger on a functional P70 briefcase computer a while ago and when asked the seller dropped shipping from 90AUD to 30AUD cause he actually checked the rate instead of putting in some random number...
Offline mougrim
« Reply #31 on: Fri, 14 March 2014, 08:05:45 »
No, I trust it could be accurate. Because, UPS. The most reasonable way to get heavy keyboard out of USA|Canada is plain registered parcel. It's about 70$ even for model F (and everyone knows how heavy those suckers are).
Offline Happy Pizza Guy
« Reply #32 on: Fri, 14 March 2014, 09:20:26 »
Could I use these to do a full replacement of the keycaps on my QuickFire Stealth?
« Reply #33 on: Fri, 14 March 2014, 09:54:52 »
$60 intl priority to Australia for the last 122-key F I bought seems quite reasonable if you ask me....
« Reply #34 on: Fri, 14 March 2014, 18:56:39 »
The USPS has excellent rateds for international postage. UPS has very expensive rates for international postage. $600 seems about right for them.
« Reply #35 on: Fri, 14 March 2014, 22:29:25 »
*Sigh*... silly sellers.... If I'm shipping internationally, I use localpost or FedEx, which last I checked would ship 5kg of a 48-port switch to Finland for ~300AUD...
Offline Charizard^
« Reply #36 on: Fri, 14 March 2014, 22:50:35 »
I just realized how cheaper USPS was about a day ago.... I shipped a pair of running shoes that were about .1 pound a month ago for $25 via UPS w/o shipping. Yesterday, I shipped a 2 pound keyboard for $12 with shipping.
Offline Maxim
« Reply #37 on: Fri, 14 March 2014, 23:32:34 »
Afraid not...  the Cherry caps lock has an off center stem.  On both the G81-3000 and 7000 there's nonstandard bottom-row modifier keys.  At least I heard something bout the 3000 having off-center stems on those keys, which just sounds awful.  Not sure about that part, but definitely the caps lock won't fit.
Offline Pacifist
  • on hiatus
« Reply #38 on: Fri, 14 March 2014, 23:36:57 »
not even close
small r shift, stepped caps, 1x 0 key, incorrect bottom row. its a no go
