Author Topic: Put another SSK on the barbie  (Read 4716 times)
Offline E TwentyNine
    • Some of My Keyboards
« on: Tue, 11 March 2014, 12:47:35 »
http://www.ebay.com/itm/141219144641
AU $195.00
Approximately US $175.89
Plus a lot of shipping if you're not local...
Offline histevenhere
  • Student
Re: Put another SSK on the barbie
« Reply #1 on: Tue, 11 March 2014, 20:48:32 »
Holybejebus, 88 shipping to US . Always interesting to see the cost of international shipping
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline RESPRiT
  • HHKB = ❤
« Reply #2 on: Tue, 11 March 2014, 20:50:36 »
Unless you're local, shipping kills it pretty hard.
« Reply #3 on: Tue, 11 March 2014, 20:51:09 »
USPS flat rate game board box international is $78 ($54 to Canada) and is the only realistic option for a heavy keyboard leaving the US.
- Plato
« Reply #4 on: Tue, 11 March 2014, 21:47:23 »
That's the kind of shipping cost we get from US to Australia all the time.
Offline strafe
    • Strafe's Blog
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline Techno Trousers
  • ʘ_ಠ
« Reply #6 on: Tue, 11 March 2014, 23:24:28 »
There are four expensive SSKs up at once now. The two aussies, one bolt mod, and one NOS. Maybe the price will finally start going down with the supply increasing like this.
« Reply #7 on: Tue, 11 March 2014, 23:25:37 »
Nice, but still above my budget :(
Here's hoping that prices do start to descend.
« Reply #8 on: Wed, 12 March 2014, 00:12:02 »
I have maild a lot of keyboards internationally and in almost every case it was cheaper to mail it priority but not flat rate.
for example a 7 lb box with impressive dimensions (20*8*4) costs under $60 to ship to Australia. Postage price is primarily determined by the weight, so flat-rate is usually only worth it for really heavy items, or dense items.
« Reply #9 on: Wed, 12 March 2014, 07:04:32 »
I recently shipped a 4 lb. 9 oz. keyboard in the same box from Georgia to California and the Priority rate was almost 30% higher than the flat rate would have been.
I shipped a relatively light keyboard to Tasmania for about $53, but that was before the last big price jump.
And, each weight has an associated size range, and the rate goes up steeply when you cross various thresholds.
- Plato
Offline Grr8
  • Quack!
« Reply #10 on: Wed, 12 March 2014, 11:42:34 »
What are thoughts on bolt modded boards?
Also, is this something that should be disclosed by a seller? Feeling a bit burnt by a purchase I made as found a board to be bolt modded when it was not mentioned in the listing.
Daily Driver: Poker II Backlit (Ducky Mini-fied) + Amazon o-rings. Future daily driver IBM AT Model F (restoring now). For fun: IBM SSK 1397681 (NIB), IBM SSK 1391472, IBM Industrial 101 Square label 1388032, IBM Industrial 101 Black label 1394946, IBM 1391401 (bolt-modding now), IBM 1370477, IBM 42H1292 (USA), IBM 52G9700 IBM, and more....
Ducky Shine w/Blues + WASD o-rings, Ducky Shine 3 TKL w/Browns + ebay o-rings, Rosewill RK-9100 w/Blues, Apple Wireless (slim), Apple Wireless White A1016, Apple Extended II ADB. Next? HHKB2Pro?
« Reply #11 on: Wed, 12 March 2014, 12:00:32 »
I'd consider that a plus, as long as the bolt mod was done properly.   The biggest pain in the ass with a bolt mod isn't installing the bolts, it's drilling all those damn holes.
Even if it were done improperly, any issues you have with the board can be fixed fairly quickly and the board will be more solid going forward.
But yes, I do think it should be disclosed by the seller if it is not apparent in the pictures.
Offline ZeDestructor
« Reply #12 on: Wed, 12 March 2014, 15:32:26 »
I'd like it to be mentioned, but overalll, I don't really care as long as it works and there are no dead keys or anything of the sort. I buy keyboards to use them, not display them in a museum.
« Reply #13 on: Wed, 12 March 2014, 19:20:33 »
That seems bizarre but could be troubling. I have done over a dozen bolt mods and I will tell you that they are a PITA.
At the minimum you have invested a couple of hours and spent at least $10 on hardware, so I would expect to be compensated for that.
Therefore, I would place the bolt-mod front and center in my ad, and expect to be paid a premium for it by someone who wanted it.
If you wanted a virgin M so that you could do the bolt mod yourself, I can see that you were very disappointed. I would have been.
Otherwise, I would have expected a bolt mod to be an upgrade worth tens of dollars at least, and if no premium price was asked, I would immediately assume that it was a botched job that the seller was just trying to unload.
But a properly-working Model M is a good thing to have. If you really want a fresh one, sell it on ebay for what you paid, and try again.
- Plato
« Reply #14 on: Wed, 12 March 2014, 20:27:09 »
Unless the seller happened to purchase the board already bolt modded, didn't realise, and sold it on without checking.
Offline smknjoe
« Reply #15 on: Wed, 12 March 2014, 20:45:02 »
Kudos to the seller for the fair pricing.
SSKs for everyone!
« Reply #16 on: Wed, 12 March 2014, 21:35:15 »
+1
But if only it was a little bit lower still ...
Offline Grr8
  • Quack!
« Reply #17 on: Thu, 13 March 2014, 00:30:37 »
I was expecting a virgin board, as the seller was someone who knew Ms. Already paid a premium because it was an Industrial 102.
There was some pinging on the number row keys, so opened it to see if there was an obvious problem, and immediately noticed the bolts.
What was also interesting is some of the bolts where one way, and some the other. I cannot remember this on any of the guides I had read.
I didn't do anything else inside, and just put it back together and put it aside to decide what I should do next...
Offline strafe
    • Strafe's Blog
« Reply #19 on: Thu, 13 March 2014, 07:34:04 »
Hard for me to understand how you would do that. I drill all my holes, clean them up, and run the bolts through from the front (top) side.
Then I turn the barrel plate over and assemble everything else in the upside-down position. I use the little bolts to stack all the layers and have everything aligned properly. The holes in the metal plate are a bit larger and will accommodate holes drilled not-perfectly-vertical.
I suppose that you could do this with some, but not all of them, but then it would be very hard to "hit" the holes exactly from the blind side. And that ridged side is where you want to be careful not to booger up the slots and tabs ("crescents" as Sandy called them).
Also, if the holes were not drilled straight, you could make the problem worse by forcing your way in from the wrong side. More, without washers, the bolt heads might almost slip through the holes.
Last, there are problems of space and fit. There is not a lot of extra clearance on either side - if the nut ends protrude too far out the bottom, you can almost hit the case at the front (spacebar) side, so using short bolts is important. On the top, you are very close to the skirt of the key when it is in the depressed position.
- Plato
« Reply #20 on: Thu, 13 March 2014, 08:30:07 »
I could see maybe on the bottom row reversing the bolts (if that would even work). If they're just randomly reversed, yeah that's strange.
But again, easily fixed.
« Reply #21 on: Thu, 13 March 2014, 08:30:21 »
Whoops, link to the more recent listing already posted.
(Really needs to be a way to delete messages on here.)
« Last Edit: Thu, 13 March 2014, 08:46:40 by E TwentyNine »
Offline Grr8
  • Quack!
« Reply #22 on: Fri, 14 March 2014, 12:21:41 »
Yes, the bottom row was reversed. And there were no washers.
