Author Topic: Looking for a tkl cherry mx green 70% size  (Read 3050 times)
Offline blackbox
« on: Tue, 11 March 2014, 14:09:25 »
Hello, I am looking for a keyboard as described in the subject title. I also want to have mx lock keys at all function keys, esc and delete key. Where can i get cherry mx lock keys?
Requirements:
  • 70% (must have individual function keys)
  • corded
  • non-backlit (or the option to turn it of)
  • mx green keyes
  • ISO layout
Edit: added list and changed the subject title from 65% to 70%
« Last Edit: Wed, 12 March 2014, 03:30:25 by blackbox »
The LAN table!
Offline zeroni13
Re: Looking for a tkl cherry mx green 65% size
« Reply #1 on: Tue, 11 March 2014, 16:25:08 »
So basically you want a 65% keyboard and then replace the switches with MX Lock keys after?
Cooler Master has a 65% keyboard called "CM Storm QuickFire TK" with MX Greens if that is what you are looking for, the MX Lock keys are something I have no idea where to get.
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline longweight
  • philanthropist
« Reply #2 on: Tue, 11 March 2014, 16:26:19 »
Get them from 7bit over at deskthority.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡ˇᴥ ͡ˇ ʔ
« Reply #3 on: Tue, 11 March 2014, 16:58:00 »
I don't think 7bit has stock on mx lock  :(
Offline Pacifist
  • on hiatus
« Reply #4 on: Tue, 11 March 2014, 17:19:02 »
I am confused.
Do you want TKL (80%) or 65% (60%+arrows)?
Good luck getting MX lock keys, 7bit is sold out, and spamray bought every lock key he could find and sold them in a GB a few weeks ago.
Offline zeroni13
« Reply #5 on: Tue, 11 March 2014, 17:32:11 »
I am confused.
Haha now you confused me aswell I just assumed he was after a TKL and reccomended the CM.
« Reply #6 on: Tue, 11 March 2014, 17:46:46 »
I am confused.
he mentions function keys, so I think he may be interested in a 70 or 70%. It's hard to know exactly what he wants. the %keyboard standard is loose at best.
From his description, I suspect the sayout he wants might be similar to this:
http://deskthority.net/keyboards-f2/nano75-a-programmable-bluetooth-backlit-75-keyboard-t7579.html
Offline AKmalamute
  • HHKB Scrub
« Reply #7 on: Tue, 11 March 2014, 17:48:59 »
are there any factory produced 65%'s? I know the pure-pro has arrow keys, and the FC660 has a couple extra keys but not quite the whole navigation cluster just a couple extras off to the side.
Can the FC660M even be had in green? I guess I should google that ... sounds intriguing, actually.
HHKB-lite2, Dvorak user
Offline Pacifist
  • on hiatus
« Reply #8 on: Tue, 11 March 2014, 17:50:46 »
Not that I know of. Only thing close is matt3o's custom board
Offline blackbox
« Reply #9 on: Wed, 12 March 2014, 02:10:06 »
I am confused.
Thanks, The keyboard you linked is the size i want. This is my "wishlist" of features:
  • corded
  • mx green keyes
  • ISO layout
In addition I am looking for mx lock keys(Seems to be very dificult).
EDIT: added ISO layout to the list
« Last Edit: Wed, 12 March 2014, 03:27:21 by blackbox »
The LAN table!
Offline tbc
« Reply #10 on: Wed, 12 March 2014, 02:37:32 »
You want all that stock or are you willing to assemble it.  If you need that stock, you're screwed.
Offline berserkfan
« Reply #11 on: Wed, 12 March 2014, 02:51:40 »
I am confused.
Now why did SpamRay do that? How many keyboards does he have?  :D
Offline blackbox
« Reply #12 on: Wed, 12 March 2014, 02:55:49 »
I Want it stock, but if it is not possible then I have to assemble it. I also have an 3d printer available if it is a keyboard that requires that.
The LAN table!
Offline RESPRiT
  • HHKB = ❤
« Reply #13 on: Wed, 12 March 2014, 03:03:42 »
75% boards are generally pretty hard to find, and with Greens probably even harder. I would look for something with the mindset that I'd have to, in the very least, end up putting in my own Green switches.
You can pre-order the KBT RACE 2 for $135 if you so desire, I can't think of any other 75% boards off the top of my head.
http://rabbitwebfactory.com/pages/kbt_race_2_limited_edition
Edit: Oh, how could I forget, have you looked into Keycool yet?
Offline blackbox
« Reply #14 on: Wed, 12 March 2014, 03:25:07 »
Thanks for the link. Forgot to mention that i want ISO layout. I have looked into keycool but i couldnt find a keyboard in the right size with ISO layout.
The LAN table!
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Looking for a tkl cherry mx green 70% size
« Reply #15 on: Wed, 12 March 2014, 03:33:05 »
I have one for sale at the moment. But I will probably send it to someone to have then switched with Clears, my favourite switch.
|||My other keyboards :
x
Offline blackbox
« Reply #16 on: Wed, 12 March 2014, 03:40:23 »
I Found out that what i whant is a 70% size keyboard. That means that a keyboard without a row of individual function keys is not an option( I know i first asked for 65% size). Thanks for the offer.
The LAN table!
