Author Topic: EK Mechlube 1 vs Mechlube 2  (Read 4108 times)
Offline morpheus
« on: Wed, 12 March 2014, 09:44:02 »
Hi guys,
Just wondering which lubricant would be the best for lubing unlubed keyboards. Or are they same?
Mechlube 1
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
Mechlube 2
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube_2
Thanks
Re: EK Mechlube 1 vs Mechlube 2
« Reply #1 on: Wed, 12 March 2014, 09:46:28 »
Offline morpheus
« Reply #2 on: Wed, 12 March 2014, 09:48:51 »
http://techkeys.us/collections/accessories/products/krytox-switch-lurbricant
^^ one of these is better :thumb:
I need it for MX Blues and Browns.
Which one should I get? Thick or Very Thick?
Also, I should tell you that I only plan to lube the stabilizers, so I don't need to get the best one out there. Is there something superior about Krytox over the Mechlube?
« Last Edit: Wed, 12 March 2014, 09:56:56 by morpheus »
« Reply #3 on: Wed, 12 March 2014, 09:59:06 »
If you not lubing switches then I guess it doesn't matter maybe, I thought since you said you needed it for blues and browns you were lubing switches.
Krytox just comes highly recommended by the majority of users.
There are some tips here
http://geekhack.org/index.php?topic=34332.msg1215360#msg1215360
http://geekhack.org/index.php?topic=34332.msg1225403#msg1225403
Personally I haven't lubed any mx switches yet, but I do have the thick and very thick lubes, I used thick on my HHKB.
« Last Edit: Wed, 12 March 2014, 10:00:54 by SpAmRaY »
Offline zoolzoo
« Reply #4 on: Wed, 12 March 2014, 13:32:52 »
I can say mechlube 1 is way too viscous for any switch. I would use Krytox... or Superlube on the cheap.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #5 on: Wed, 12 March 2014, 14:54:31 »
I've used Mechlube 1 for lubing costar and Cherry stabilizers, and it's worked great for me :thumb:
« Reply #6 on: Wed, 12 March 2014, 15:02:37 »
I used the mechlube 2 for my stabilizers in my hhkb the first time and it did the job but I used the Krytox mix thick version from mkawa (techkeys, originative) on all the slider housings and stabilizers this time and it works amazingggggggggg.
Offline Folio
  • I'm a nice guy.
« Reply #7 on: Thu, 13 March 2014, 08:48:47 »
It's all lube in the end. I got the Blue Mechlube just for stablizers. Works fine. Which ever is cheaper I guess.
« Reply #8 on: Thu, 13 March 2014, 09:02:02 »
^^ Everyone has opinions on lube just like switches, springs, key caps, etc. However all lube isn't created equal and getting the cheapest option is not the best advice.
Offline Folio
  • I'm a nice guy.
« Reply #9 on: Thu, 13 March 2014, 09:16:30 »
Just spray some WD-40 in there.  ;)
« Reply #10 on: Thu, 13 March 2014, 09:37:30 »
