Author Topic: UK Keyboard advice Das/Filco/WASD  (Read 1816 times)
Offline naxtek
« on: Thu, 13 March 2014, 18:51:09 »
Hi!
I'm looking for a new keyboard for work.  I'm a programmer.
I've decided my new keyboard should:
  • Have brown Cherry MX switches
  • Have proper UK 105-key layout
  • Ideally not have a Windows key (I'm an Ubuntu user)
  • Be nice to look at (I'm a minimalist, so things like blank keys appeal)
  • Be full-size
I've narrowed it down to three possibilities which fit my requirements:
Das Keyboard Ultimate Model S
Pros:
  • Available in UK
  • Blank keys (look cool IMHO and no Windows key)
  • Cheapest
  • USB hub built in
  • Media functions
Cons:
  • Searching seems to suggest the Das might not be great quality?
  • People seem to say the gloss finish shows up finger prints
  • Bezel is thicker than some others
Filco Ninja Majestouch-2
Pros:
  • Available in UK
  • Blank-ish keys (look cool, but not as nice as the Das IMHO)
  • Reasonable price
  • Seems to get good reviews
Cons:
  • Not as nice to look at as the Das IMHO
  • Windows logo (bleurgh) although it is discreet on the Ninja
WASD v2
Pros:
  • Customisable so can have whatever I like - blank keys or anything
  • I like the media key arrangement best
  • Option to have a nice Ubuntu logo on the super key
Cons:
  • Have to ship from US (delay)
  • Nearly twice the price of the others when shipping & import tax is added on
I was just wondering what your opinions were?  Are there any others I should consider?
Offline BlueBär
Re: UK Keyboard advice Das/Filco/WASD
« Reply #1 on: Thu, 13 March 2014, 19:34:43 »
You seem to have informed yourself quite well about your options - great!
The gloss on the Das attracts fingerprints and also gets dirty fairly easy. Quality-wise, they switched manufacturers and it used to be better, so it depends on what version you get.
Filco is a good option that is often recommended, always a good choice. You can get replacement blank keycaps fairly cheap if it bothers you.
With WASD, I really think after taxes etc. the higher price compared to the Filco isn't worth it.
Offline naxtek
« Reply #2 on: Fri, 14 March 2014, 11:02:00 »
Thanks, have gone for the Filco Ninja!
« Reply #3 on: Fri, 14 March 2014, 14:17:22 »
A very wise decision, sir!
Offline longweight
  • philanthropist
« Reply #4 on: Fri, 14 March 2014, 14:21:59 »
Here you go :D
http://www.keyboardco.com/product/ubuntu-logo-windows-keys-2-keycaps-for-cherry-mx-switches.asp
Ah balls just realised that you have gone for a Ninja board.
« Last Edit: Fri, 14 March 2014, 14:26:25 by longweight »
Offline nereme
« Reply #5 on: Fri, 14 March 2014, 14:29:16 »
Filco Ninja Majestouch-2 I happily vote for this as I have had one for just over a year and love it
Offline matt303
« Reply #6 on: Fri, 14 March 2014, 15:40:13 »
Hope you enjoy the Filco, got that one myself but with blues, the Win logo is not so noticeable on the Ninja.
