Author Topic: 3D Print Caps - Shapeways  (Read 4501 times)
Offline mindoculus
« on: Thu, 13 March 2014, 21:57:26 »
Hey there:
I thought you might like to see a few 3D keycaps I recently received from Shapeways.
All the keys were made in polished plastic (type unknown). They have the feel of fine
paper and are rather light. With two of them, you can still see the whorls. The polish
needs to improve but overall I'm thrilled to have them and look forward to ordering
more.
First four are by Ravenzcroft; last one by Tasker.
The fit for this first key has unfortunately deteriorated. The material around the stem
has chipped. I might be able to get a fit using some scotch tape but it appears that it
will continue to crack. Sad because its my favorite.
Tasker's:
« Last Edit: Thu, 13 March 2014, 22:01:42 by mindoculus »
Re: 3D Print Caps - Shapeways
« Reply #1 on: Thu, 13 March 2014, 22:21:02 »
They look pretty good.
Any pictures of the underneath of the keycaps?
Offline RESPRiT
  • HHKB = ❤
« Reply #2 on: Thu, 13 March 2014, 23:40:14 »
Thoughts on the quality? I've never thought 3D caps were worth it, but I'm interested in what you think.
Offline mindoculus
« Reply #3 on: Fri, 14 March 2014, 09:17:08 »
Sorry it couldn't be clearer. I'll try for a better potato shot later.
Offline mindoculus
« Reply #4 on: Fri, 14 March 2014, 09:34:40 »
The keys are thin and light-weight – yes, ABS thin and light-weight, which I think is the type of plastic filament they used. They could have benefitted from a deeper rendering because it doesn’t take much pressure to flex their sides. With that said, I am not planning to stand on them so they should be fine. I love the textures. They’re finely coarse but worlds different than the flocked keycaps sold by TechKeys. You can see the whorls from the printing process on two of them. Of the seven keys I received, only one has trouble with fitment, and I don’t think it can be repaired.
Offline nereme
« Reply #5 on: Fri, 14 March 2014, 13:05:25 »
So they seem like if they were hit hard or summit they would break?
what do you think would improve the caps if you were to do them 'properly'
are the astetic issues with them just some after manufacturing tlc e.g sanding or something like that?
« Reply #6 on: Fri, 14 March 2014, 23:40:29 »
Looks as good underneath as it is on top.  Strengthning bars, well-formed stem - nice :)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7 on: Fri, 14 March 2014, 23:42:41 »
That 3d GH key looks neat!!
Offline do_Og@n
« Reply #8 on: Sat, 15 March 2014, 00:22:17 »
Those look surprisingly better than I though they would.
Well done! I'm eager to see your progress on this.
Offline RaVNzCRoFT
  • * Commercial Vendor
« Reply #9 on: Sat, 15 March 2014, 14:45:27 »
If I may do a bit of self-promotion, most of these keycaps were designed by me and purchased through my keycap shop, K3YD.  I take requests for free.  If you click the link in my signature, you can go to the thread where you can see more information and make requests.
« Last Edit: Sat, 15 March 2014, 14:47:07 by RaVNzCRoFT »
<<< Click to view
Offline HipsterPunks
  • Gangnamember
« Reply #10 on: Sat, 15 March 2014, 15:01:19 »
im confused? is geekhack trademarked? or can anybody make a geekhack key?
sell ass and eat out
Offline fatchoi
« Reply #11 on: Sun, 16 March 2014, 00:37:30 »
Looks good. I'm thinking to learn 3D modeling to make my own key caps. (e.g. my initials, birth year, etc.)
Possible to share some 3D models?
Offline meiosis
  • Time
« Reply #12 on: Sun, 16 March 2014, 01:25:33 »
you can't trademark "gh" maybe GEEK HACK though but even then the copyright laws/money needed is not worth it.
Keyboards:
Aripeko TKL
Offline simon_C
« Reply #13 on: Sun, 16 March 2014, 20:39:18 »
Those look like the standstone material. Have you tried any of the high resolution plastics available yet?
