Author Topic: [SPRiT] MX ALPS Springs/ LSS Lube/ Stabilizers/ Cherry RGB Clear (CLOSED!!!!!!!)  (Read 1514541 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Okay so considering this "group buy" is over a year old, if I go into the order form and select 62g and 65g gold springs, those should be in stock and ready to ship, yes?
Yes but get in touch with SETH(The US proxy) as he was making a large order and he'll have his stock soon.
Okay, thanks. Is this the order form I should be using?
http://goo.gl/forms/jOH6CPKeOg
Yep :)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
All the Springs are shipped out!   ;)
New v1.2 are  All 24K Gold plated Now  -  24KGP
I have been testing and producing, since last December, completed the line up.
How it feels?   Let's share Your field reports!  If not good, i can change it back to 18KGP.
Thanks Guys!
« Last Edit: Fri, 24 July 2015, 04:55:13 by sprit »
Offline ys9527
All are shipped out!   ;)
New v1.2 are All 24K Gold plated.  -  24KGP
I have been testing and producing, since last December, completed All the line up.
Thanks Guys!   ;)
Will I be getting any notification of the shipping.
Because I did not get any in the past weeks.
Offline sprit
I am preparing the Packing  ;)
Offline lishi
  • Luxury Taste Buds
    • Personal Website
Hey Sprit, are stabs still available?
All the kustom 60s
Offline Metr0
  • HHKB or nuttin
How many springs are in a set?
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline wlhlm
Offline Metr0
  • HHKB or nuttin
Are the PCB mount stabiliser wires straight or bent?
Offline wlhlm
Straight
Offline Blackehart
No more 85g? QQ
Some inbred asshat stole mine from the mailbox.
I was wondering when you would have 85g back in stock and if it could be possible to get a signature request?
EDIT: AH! the worldwide link has 'em.
Would still like to know if I could possibly get signature request on the package.
EDIT2: Order placed!
« Last Edit: Fri, 24 July 2015, 11:35:29 by Blackehart »
Offline sethk_
  • www.kbdhub.com
    • My webstore
No more 85g? QQ
you can request them in the comments section as far as US/CA order form goes
Offline nephiel
I got today the plate mount stabs I ordered, along with 3 RGB LEDs and 6 55g springs. Funny, I don't remember ordering anything other than the stabs.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline rpeterclark
  • RPTR ❌
He likes to throw in fun extras! :-)
Hey Sprit, I ordered plate mount stabs, along with 3 RGB LEDs and 6 55g springs. They say delivered but I haven't gotten them.
Offline rpeterclark
  • RPTR ❌
Mystery solved.
Mystery solved.
I was just messing. I'm a weird dude.
Offline pkircher
he puts 3 rgb lights into every order + the harder springs are for the spacebar .. then number varys dep on the ordersize
Offline nephiel
That's nice. Thanks SPRiT!
Offline kaminbobby
  • -_^
Just made an order for 68g springs some lube and stabilizers!
does anyone have a newbie guide for lubing springs btw?
-_^
Offline awhitedev
Take a small hobby paint brush and dab it into your lubing mixture. I find the less viscous the lube the better when it comes to springs. Then, hold the spring on one end with some tweezers and very lightly brush one side of the spring. Then, put the spring in the the switch housing with the side you just lubed facing down... try to do this without touching the lubed side. Then, continue lubing the other side with the spring in the housing. And remember: a little lube goes a long way... especially with springs. If you put too much the switch will feel mushy or gritty.
Hope this helps!
Offline nephiel
I'm going to try the color-changing RGB LEDs. Anyone know what resistor should I use?
Offline StinkyTheDonut
  • I like rubber domes.
Hope this helps!
When you say side, you mean the ends right?
I only have a washable keyboard.
Offline sprit
Thanks!  Amigo!   ;)
The RGB LEDs work well with any resistors,  a bit better with a PCB for White/Blue LEDs
« Last Edit: Mon, 27 July 2015, 21:52:05 by sprit »
Offline sprit
Hi!  I am back from a Weekend break!    ;)
Offline sprit
Hello!  :)
Have You ordered on the USA/Canada Order Form?
Offline sprit
Mystery solved.
Hi!   Hows going, rpeter!   ;)
Seems Not yet.   I take pics for Every package as You know.
For nephiel,  I put extra 3 RGB LEDs and several Evaluation pcs of Springs into his Box.
romevi  have ordered on the USA Proxy form.
Ordered 62g for Clears and 65g for Blues. Would any of these springs be good to try Ghetto Greens and Pandas?
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
I  just got my shipping notice! Thanks so much, Sprit. I'm really excited to get those stabilizers and complete my build!
Any news on costar wires? Was there also a mention of 1.3 springs earlier?
I'm just curious if those things are still happening.  ;D
Offline strict
  • TKL Zealot
Seriously, I've been trying to find a 7x Costar wire for coming up on a year now. Im willing to sign over my everlasting soul for one at this point.
Offline Phirr
  • If you don't work you die.
Thanks, everything arrived in good condition
Offline Metr0
  • HHKB or nuttin
Stuff came in today SPRiT, everything is great condition :D
Offline bcredbottle
Offline sethk_
  • www.kbdhub.com
    • My webstore
Once the last invoice gets paid I am sending in the order.
Ah, okay. I almost forgot I ordered some and then started to wonder when I'd get them!
*monkey dance*
Offline retrochick
  • goodbye my wallet
Just received mine. 55g and 62g gold plated springs + lube. Sprit also threw in a pleasant and unexpected surprise!!!!! Thank you SPRiT!!!!!  :thumb: :thumb: :thumb:
Offline bcredbottle
For the ALps springs??
Offline sethk_
  • www.kbdhub.com
    • My webstore
No, proxy for Gold cherry springs
Offline bcredbottle
Do you know when the Alps spring buy is happening?
Offline sethk_
  • www.kbdhub.com
    • My webstore
Nope, sorry
Offline sprit
Hoply very Soon!   ;)
Offline Karura
  • Professional Canadian
  • SKidata life.
Hoply very Soon!   ;)
Do you have enough reference springs? It would be nice if you could post a comparison and offer gold springs like you already do for MX.
Offline caseyandgina
Hope these are still available, I just filled out the Google form!
Offline waterform
Springs arrived! I'm glad I bought five different weights, I'll find uses for all of them. Thanks sprit.
Offline goflo
Another order placed....  going for the soft ones this time.  :cool:
- Ergodox Classic/Browns/Grifiti Rests  | - IBM Model M Blue Label |  - Poker II MX Blue | - Ergodox Classic/Blues/Grifiti Rests
Offline sethk_
  • www.kbdhub.com
    • My webstore
If you filled out and paid for the springs from the US proxy I have them all packaged up, and they will be going out tomorrow :)
Offline Steezus
  • Keeper of Facts
I accidentally screwed up the address, how to I edit my form?
Offline sethk_
  • www.kbdhub.com
    • My webstore
Just PM me if it is in my spreadsheet, or contact sprit if it is with him
Offline Steezus
  • Keeper of Facts
I sent sprit a pm, so to my understanding this isn't really a group buy but kind of like a store? It's a little confusing trying to read everything this thread is huge.
