Author Topic: 5 pin DIN IBM Boards  (Read 3411 times)
Offline user 18
« on: Fri, 14 March 2014, 15:45:20 »
Has anyone had success using 5 pin to ps2 converters with IBM boards? Does it tend to work with certain families of boards and not others?
I've successfully done this with several old boards, and I have a converter lying around. I just want it to be a sure thing before I shell out for say a model M with a 5 pin connector.
Avatar by ashdenej
Offline JPG
  • Model F is my new passion!
Re: 5 pin DIN IBM Boards
« Reply #1 on: Fri, 14 March 2014, 15:47:47 »
The AT protocol can be converted with a passive converter. The XT protocol can't. M keyboards should be AT as far as I know, but don't take this for cash and make sure.
Wait for someone to confirm what I just said!
Offline user 18
« Reply #2 on: Fri, 14 March 2014, 16:03:50 »
Thanks for the response. As an addendum to my prior question, what are the chances of chaining it with a ps2/USB converter as well? Good as long as it makes it to ps2, or flaky at best?
Avatar by ashdenej
Offline Touch_It
« Reply #3 on: Fri, 14 March 2014, 16:33:12 »
Chances should be exactly the same as straight ps2 to usb in theory as the din to ps2 only changes the adapter size and not wiring.  All comes down to the usb adapter.
« Reply #4 on: Fri, 14 March 2014, 16:33:32 »
All of these are straightforward and easy with an old Model M (1390120, 1390131, or early 1391401, etc) or Model F AT that simply came with the large plug instead of the smaller PS/2 style. And you can plug a newer cable into the Model Ms, but not the Fs. The USB step works, too.
If it is a Model F XT or similar, the plug is the same but the protocol is not. It will not work.
Note: I am not a gamer so I probably have lower expectations than many other people.
- D Trump 2026-10-24
Offline user 18
« Reply #5 on: Fri, 14 March 2014, 17:16:50 »
I somehow doubt I'd come out the other side wanting to use a BS board for gaming. I have a feeling I'd love one for typing though. Thanks for the advice everyone, and I'll be trawling through ebay and the like looking for something affordable.
Avatar by ashdenej
« Reply #6 on: Fri, 14 March 2014, 18:22:44 »
If you buy an IBM Model M without a a cable, get one from Orihalcon.
These are great and handsome, and go straight to USB.
http://www.ebay.com/itm/USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Type-M-Clicky-Keyboard-Cable-NEW-/280862986246?pt=LH_DefaultDomain_0&hash=item4164bd1006
Offline mougrim
« Reply #7 on: Fri, 14 March 2014, 18:25:18 »
Oh, nice! If I'd ever get genuine Model M, I'd get one of those :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
« Reply #8 on: Fri, 14 March 2014, 23:36:19 »
+1
I have one that allows my Model M to work faultlessly with my Mac :)
