Author Topic: Chyron Max keyboard: lots of MX clear switches, bids starting at $48 shipped  (Read 2703 times)
Offline jacobolus
I was considering bidding on this, but now I'll let GH have at it. These are pretty common, so I'll wait for the next.
The one I got a while back didn't have clears. :(
Offline jacobolus
Judging from the way the caps lock key looks in the picture, this one looks identical to all the MX clear versions I’ve seen pictures of, and distinctly different from the other (foam and foil?) versions.
Offline False_Dmitry_II
Is that thing just gotten for switch harvesting?
Offline jacobolus
I assume you could also try to put a teensy in there and get it working.
Keep your keyboard layout on a floppy disk!
Offline berserkfan
Is it even usable for modern purposes? It's huge, it sucks power, it needs modding, it's got a distinctly uncool looking floppy drive... the only people who could want to buy it are those desperate for clear switches...
Offline ZeDestructor
If you're gonna mod (and you have to to make it talk modern), do it right and fit a new controller into the existing matrix. As a side result, this eliminated the power-hog thing entirely. As for the floppy drive, it's cool visual piece at this stage.... Or you could replace it with a little matrix display or something else fun to complement the existing matrix display. Personally I'd turn it into a dock for my phone.
Doh, nobody bid on it :eek:
Offline jacobolus
I know everyone said this looks like the one with clears but I'm just scared I'll get another foam and foil :P
Offline jacobolus
Look at the caps lock key. It’s the same as this one: http://www.ebay.com/itm/380370298939
The caps lock on the foam and foil version looks like: http://www.ebay.com/itm/151216102438
