Author Topic: Recommend me a pair of Scissors  (Read 4341 times)
Offline Pacifist
  • on hiatus
« on: Sun, 16 March 2014, 13:30:39 »
Broke my pair of scissors  :'(
Need a new pair, what does everybody recommend?
Re: Recommend me a pair of Scissors
« Reply #1 on: Sun, 16 March 2014, 14:26:51 »
What do you use them for?
Offline blackbox
« Reply #2 on: Sun, 16 March 2014, 14:38:26 »
What kind of scissors do you need? Is it for paper(I guess it is)?
You should try a scissor from fiskars.
The LAN table!
Offline Tym
« Reply #3 on: Sun, 16 March 2014, 14:48:30 »
These any good?
« Reply #4 on: Sun, 16 March 2014, 14:49:46 »
I have some Henckels that are pricey but great.
Only use cheap-ass scissors on paper, it ruins them.
Japanese garden scissors are amazing, too.
- D Trump 2026-09-28
« Reply #5 on: Sun, 16 March 2014, 14:50:45 »
Sharp ones.
Offline blackbox
« Reply #6 on: Sun, 16 March 2014, 14:55:11 »
Sharp ones.
Good advice, I do agree.
The LAN table!
« Reply #7 on: Sun, 16 March 2014, 15:03:20 »
For general purpose usage, I like the paramedic style scissors.
« Reply #8 on: Sun, 16 March 2014, 16:34:34 »
Yes. That angled end bit is super useful for smaller spaces.
Offline Oobly
« Reply #9 on: Mon, 17 March 2014, 06:02:05 »
Anything from Fiskars.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline morpheus
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #11 on: Mon, 17 March 2014, 06:37:56 »
I have a pair of Kokuyo non-stick scissors. Because the blade has a slight bump it won't just fold over when cutting paper and it's much easier to clean
|||My other keyboards :
x
Offline fatchoi
« Reply #12 on: Mon, 17 March 2014, 21:07:22 »
Titanium version
http://www.amazon.co.uk/scissors-Superiore-titanium-glue-less-Hasa-PH240D/dp/B00BDY739S
« Reply #13 on: Mon, 17 March 2014, 21:08:11 »
Ignore the stock image bull****
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #14 on: Mon, 17 March 2014, 22:16:25 »
Tough-cuts are useful to just have on you, or have in a First Aid Kit, but I would say you want a set with plastic handles and about a 4-6 inch blade for paper, the longer blades giving you enough length to cut through card and stuff.
Offline charlaph
« Reply #15 on: Wed, 26 March 2014, 14:00:36 »
Leatherman Raptor.  http://www.leatherman.com/831741.html
Seriously though I have a pair of Henckels which are amazing, they came with a set of kitchen knives and have been abused for almost 10 years but are still super sharp and robust.
Offline blackbox
« Reply #16 on: Thu, 27 March 2014, 02:48:25 »
What an amazing pair of scissors(raptor)!  I use my wave every day and if I wanted to upgrade to a larger scissor, the raptor would be my first choice now.
The LAN table!
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
« Reply #17 on: Thu, 27 March 2014, 18:19:09 »
http://www.amazon.com/Klein-2100-8-Free-Fall-Stainless-Steel/dp/B0015SBIL6/
These are very sharp, and don't dull easily even after cutting wires constantly.  I use them primarily for cutting cable obviously, but I also use them for everything else including trimming my dog's fur, opening boxes, cutting paper, etc.  Even if you don't work in telecom, these snips are sharper and more durable, therefore better than any other scissors EVAR for most uses!  For high force cutting needs you just put your middle finger in the small hole and use your palm to compress the scissors.
Offline PointyFox
« Reply #19 on: Thu, 27 March 2014, 19:12:31 »
Westcott ExtremEdge Adjustable Tension Titanium Bonded Scissors for general purpose and Feather switch-blade shears for hair or thread.
