Author Topic: 88/105 ISO PBT set?  (Read 3383 times)
Offline Bakgrund
88/105 ISO PBT set?
« on: Sun, 16 March 2014, 15:33:46 »
Hey, I'm looking for a full 88/105 set ISO pbt keycap set but it's more trouble than i expected, so that's what i need help with, finding a pbt iso set priced reasonably.
I've found multiple good priced ansi pbt sets but no iso pbt caps for around the same price, i've googled multiple times but can't seem to find anything of value.
I found this great pbt ISO set at QWERkeys but they seem to be out of stock, and do they even sell to normal individuals or just companies? http://www.qwerkeys.co.uk/product/pbt-iso-105-key-cap-set/
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline ideus
  • Björkö.
Re: 88/105 ISO PBT set?
« Reply #1 on: Sun, 16 March 2014, 15:48:52 »
You may consider to join the upcoming GB for a PBT DSA set with sublimated legends. While its profile is different than OEM or cherry, it will be very cool. It will have all the keys to get a full ISO set.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2 on: Sun, 16 March 2014, 16:06:58 »
can you link this set?
Offline ideus
  • Björkö.
« Reply #3 on: Sun, 16 March 2014, 16:37:47 »
You can use the link to the IC in my signature.
Offline longweight
  • philanthropist
« Reply #4 on: Sun, 16 March 2014, 16:43:36 »
Only problem with that is that the ISO enter is the wrong profile :(
Offline ideus
  • Björkö.
« Reply #5 on: Sun, 16 March 2014, 16:44:24 »
What profile are you looking for? Have a pic?
Offline imbattable
« Reply #6 on: Sun, 16 March 2014, 19:12:38 »
I think he means that SP has no ISO Enter mold for DSA, resulting in a DCS Enter in the GB.
Offline ideus
  • Björkö.
« Reply #7 on: Sun, 16 March 2014, 19:16:47 »
Well, that's right. But I read it fits the DSAs mostly.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8 on: Sun, 16 March 2014, 21:17:16 »
Oh. Thanks. I am not interested in buying sp caps. I like thicker caps.
