Author Topic: [IC] Universal 104/108 Plate  (Read 67010 times)
Re: [IC] Universal 104/108 Plate
« Reply #150 on: Tue, 21 October 2014, 16:53:23 »
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #151 on: Tue, 21 October 2014, 17:00:10 »
Hey guys, sorry for lack of updates on my end. Last time I talked to jd about it, he was tweaking the plate design I believe.
I have been kinda busy with real life for a while, first getting ready for baby, and then dealing with him actually coming. Our first child, a boy, was born October 8th, and between that and work I have been swamped. He was three weeks early, but all is well. When things settle down for me, I still intend to do a run of these from my local cutter.
Congrats mate!
No rush with the plates. Just enjoy your time with the little one.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
« Reply #152 on: Tue, 21 October 2014, 17:06:37 »
I would take one here please.
A kid?
Well that is one way to drop the hint, since Mrs. Melvang is also a member here.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #153 on: Wed, 22 October 2014, 08:32:58 »
A kid?
No more kids for me.  I got the big snip after our daughter.  I just want a plate in ANSI 125.
« Reply #154 on: Wed, 07 January 2015, 16:56:24 »
Offline beltet
« Reply #155 on: Sun, 11 January 2015, 06:25:38 »
If it would get some ISO love I'm interested.
Offline honoka
« Reply #156 on: Sun, 11 January 2015, 16:59:48 »
What he said.
I'd buy 5 ISO-plates to start with :)
Offline ThomasBastiani
« Reply #157 on: Thu, 22 January 2015, 10:02:20 »
I'm in for 2 plates. I would appreciate stainless steel but I'll take aluminium otherwise. :-)
Offline jchamer
« Reply #158 on: Sun, 01 November 2015, 12:12:45 »
I would love either a plate if this is still active or a drawing file if somebody can get me one
Offline whiskytango
  • Don't touch the trim
« Reply #159 on: Mon, 02 November 2015, 12:27:31 »
So, I was going to get a run of these done using jd's design a little over a year ago. I got a prototype one-off made and we figured out that it needed some changes to fit a ducky, but it fit my rosewill fairly well. jd was going to make the necessary changes to the design (which he did) and then I was going to do a run at a cutter that is local to me. I did not get this done before my son was born in October last year, and nothing has really been the same since, lol.
A few months ago, I got back in contact with jd about following through and doing a run of these. I got the most updated cad file from him and got a quote for a run of 50 plates. However, once again, I got busy with life and did not follow through.
I did at least do some work on actual numbers. If the quote the cutter gave me is still accurate, I think I can get these done for about $30 per plate. That covers everything except shipping.
So if there is enough interest for about 50 orders, I can still do this. I would not take any money until plates are in hand. If there's still interest, I will ask to start a group buy.
My time is limited, so I would want to keep the order limited to 50.
So, do people still want these?
EDIT: I should mention, this design fits ANSI only. I did not make the design, all credit for that goes to jd. If you want him to do an ISO design, you can ask him, but this buy will be for ANSI only if I do one. I am not prepared to have it be any more complicated than that.
« Last Edit: Mon, 02 November 2015, 12:30:20 by whiskytango »
« Reply #160 on: Mon, 02 November 2015, 16:51:11 »
I'll definitely be getting at least one of these. :cool:
I'll still definitely be getting one of these if they happen.
Offline jchamer
« Reply #161 on: Tue, 03 November 2015, 18:13:49 »
Well it's understandable that life got in the way, but after some looking I think I'll just prototype my own at a local makerspace.
« Last Edit: Tue, 03 November 2015, 22:03:06 by jchamer »
Offline studyourheart
« Reply #162 on: Sat, 14 November 2015, 11:23:36 »
I would definitely be interested in a couple of these!
Offline Giorgio
« Reply #163 on: Sat, 14 November 2015, 12:48:52 »
Very interested if it's compatible with a gon or winkeyless full size pcb
« Reply #164 on: Sat, 14 November 2015, 13:19:52 »
I'm not sure if the spacing between the alphas and the F-row is the same for those custom PCBs as it is for stock keyboards. The intent of this plate is to swap out the stock plate for this one in keyboards like Filco, Ducky, etc., so you can open the switches later without desoldering. And you could for instance switch the stabilizers in a Filco to Cherry instead of Costar.
Offline Oobly
« Reply #165 on: Sun, 15 November 2015, 13:58:37 »
I'm definitely interested in getting two of these if the GB goes ahead :D
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline FreeCopy
« Reply #166 on: Sun, 15 November 2015, 14:02:05 »
Definitely in for one.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #167 on: Sun, 15 November 2015, 14:17:19 »
I don't know how best to advertise this, but people need to be made aware that this plate works equally as well for an 87-key as for a 104/108-key. One plate for full size and TKL!
I see WTB threads in Classifieds all the time searching for Universal TKL plates...
Offline TalkingTree
    • My projects
« Reply #168 on: Fri, 20 November 2015, 10:25:53 »
Looks like the Filco PCB is universal (there are holes for ANSI, ISO and JIS).
How about an universal plate?
« Reply #169 on: Fri, 20 November 2015, 10:29:49 »
It can't work like that, unfortunately, because of the need for plate mounted stabilizers. Sorry. You're not the first to ask - I get asked this all the time.
Offline TalkingTree
    • My projects
« Reply #170 on: Fri, 20 November 2015, 10:52:50 »
Right, I didn't think to that.
My bad, sorry.
« Reply #171 on: Fri, 20 November 2015, 10:57:19 »
My bad, sorry.
No need to apologize, I just didn't want you to feel like I was shutting you down out-of-hand. :)
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #172 on: Fri, 20 November 2015, 11:38:54 »
Looks great!  Unfortunately I'd only be able to use it if it was compatible with Varmilo VA87MR or WASD CODE 87 though.
[WTB] HHKB Black
« Reply #173 on: Fri, 20 November 2015, 11:41:02 »
Not sure about the Varmilo, but I think it's probably compatible with the CODE. I know for sure it will work with the KUL ES-87. :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #174 on: Fri, 20 November 2015, 13:22:43 »
As i have said before. I can produce these plates in various materials used and if it is needed. I would like to see an ISO option since the universal is not possible because of plate mounted stabilisers.
Carbon Fiber
Steel
Aluminium
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #175 on: Sun, 22 November 2015, 10:11:48 »
Okay i got the files, ready for production and orders. I need a proxy in the US that can ship all the american and international orders. I will take care of Europe if it is cheaper than just sending it via the US proxy.
I can't have all the options that i have in the current GB, however you can discuss if you would like some colors, or materials especially.
2-3 options would be fine.
« Reply #176 on: Sun, 22 November 2015, 11:47:59 »
IMO, stainless and a couple anodized alu colors would be great. I love the black and red plates I got.
Offline TalkingTree
    • My projects
« Reply #177 on: Sun, 22 November 2015, 12:14:03 »
I believe black should be the first option since many of these keyboards have black plates. Correct me if I'm wrong.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #178 on: Sun, 22 November 2015, 12:31:34 »
Also JDcarpe, the price will almost be the same with the tenkey removed as an option. Just so you know.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #179 on: Thu, 26 November 2015, 14:31:45 »
Yeah i will probably run this at the same time as the HHKB plates.
I need a US shipper, let me know if you want to do the hard work.
Offline punkpc
« Reply #180 on: Wed, 27 April 2016, 16:57:00 »
Any hope that these might still get made?
If not will the file become available so I could get a couple cut for myself?
Thanks
Offline Jumie
« Reply #181 on: Thu, 28 April 2016, 07:07:03 »
Thanks
I heard Jd will run another gb for his plate
Offline punkpc
« Reply #182 on: Thu, 28 April 2016, 07:14:10 »
Thanks
I hope so... I would like to get a few of these plates.
Thanks for the info  :thumb:
Offline punkpc
« Reply #183 on: Fri, 03 June 2016, 12:55:30 »
If there isn't going to be another group buy on this, is there a way to get the file so I could do a short run?
Just wondering because I have a few projects that could use these.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #184 on: Thu, 16 June 2016, 16:54:47 »
If this IC is still active, I would be interested in an ISO-compatible plate if that is an available option.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
« Reply #185 on: Thu, 16 June 2016, 17:16:28 »
It's pretty much dead.
Offline whiskytango
« Reply #186 on: Thu, 16 June 2016, 18:42:05 »
Did leandren never do a run?
« Reply #187 on: Thu, 16 June 2016, 20:59:43 »
Nope. He said due to the larger size shipping was too much of a hassle.
Offline balancebox
« Reply #188 on: Fri, 14 October 2016, 22:24:18 »
interested in 1-2 for my filco maj2 and a cmstorm TKL
Filco MJ2 104 w/ Cherry Black | Filco MJ2 104 w/ Cherry Brown | KBT Pure w/ Cherry Blue | CMStorm QFR w/ Cherry Ghetto Green | Ducky One w/ Gateron Green |
Offline WNovizar
« Reply #189 on: Thu, 20 April 2017, 05:38:09 »
Is this still happening?
I like mechanical keyboards
Offline punkpc
« Reply #190 on: Thu, 11 May 2017, 16:56:01 »
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #191 on: Tue, 13 June 2017, 12:34:22 »
We now have them available on MechanicalKeyboards.com should anyone be interested.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
