Author Topic: Poker II not registering keys.  (Read 1841 times)
Offline pahjay
« on: Mon, 17 March 2014, 20:28:01 »
Hi everyone,
I recently ordered a white poker II with brown switches from Qtan on ebay. Upon arrival, many of the keys only intermittently worked. I have tried resetting the firmware, doing a factory reset, and using the programming mode to rebind the keys. One of the screws was stripped on arrival so I cannot take the case off without drilling through the screw, and if I have to return it I don't want to drill through the screw. Any suggestions?
Here is a link to show you which keys are not working.
http://i.imgur.com/azdBirC.jpg
« Last Edit: Mon, 17 March 2014, 20:30:36 by pahjay »
Offline mougrim
Re: Poker II not registering keys.
« Reply #1 on: Tue, 18 March 2014, 06:18:00 »
Hi everyone,
Return it. Not registering keys, missing screws...
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline nobee
  • Topre! Topre! Topre!
« Reply #2 on: Tue, 18 March 2014, 08:06:02 »
Hi everyone,
You should be able to return it within 14 days. I think shipping costs will be covered for DOA items, but best to check with qtan himself.
ReΛlforce 87U (55g)   Leopold FC660C (Silenced/Lubed)   Leopold 210TP MX Red   Filco Majestouch 2 Ninja MX Brown
Offline pahjay
« Reply #3 on: Tue, 18 March 2014, 11:00:43 »
Is his ebay the best way to contact him?
Offline irendulic
« Reply #4 on: Tue, 18 March 2014, 15:03:48 »
He might respond here if he sees the topic. Send him an ebay message and link him to this topic.
Offline ideus
  • Björkö.
« Reply #5 on: Tue, 18 March 2014, 15:30:26 »
Contact him directly. Use the same place where you purchased the board. He has ebay and its own site. Also he has a vendor forum here. You can post there as well. The more direct the better. And also I think to contact him first would be better than post here. Anyways.
