Author Topic: Hi-Tek Space Invaders installation, etc  (Read 2394 times)
« on: Tue, 18 March 2014, 12:45:47 »
I wanted to replace a couple of Hi-Tek switches that are semi-broken, that is, they still work but aren't quite "right" due to bent leaf, stretched spring, etc.
I have a donor board but can't seem to remove the switch. There are 4 legs, and I de-soldered each of them completely. At that point you can usually pull the switch out, even resort to pliers if necessary, but these seem tight.
I tried levering them up with a small screwdriver while heating the back, and even switched to a pointed tip on my soldering iron to push the pins out. In each case, it was able to push the leg in by about 1mm-2mm, and it seemed to have disengaged entirely from the solder joint, but it was still affixed tight to the board.
Are Hi-Teks mechanically fastened, or is there some trick to getting them off?
- D Trump 2026-10-24
Offline skrsh3r
Re: Hi-Tek Space Invaders installation, etc
« Reply #1 on: Tue, 18 March 2014, 15:59:21 »
When you desolder them just squeeze those plastic tabs that arrows point at with some needle nose pliers while at the same time pulling whole switch up
« Reply #2 on: Tue, 18 March 2014, 19:49:01 »
Thank you very much!
Exactly what I needed to know!
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #3 on: Wed, 19 March 2014, 01:31:18 »
the last poster is right. you may have to be careful of another thing: these switch legs dont have any stress relief, so if you overheat, the inside contacts mis-align. be careful, desolder completely and then slowly press the tabs 'in' to wiggle the switch out.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
