Author Topic: Thick PBT search  (Read 8673 times)
Offline zippox
Thick PBT search
« on: Tue, 18 March 2014, 20:18:26 »
So to get right down to it, I'm looking for the least expensive way to get thick PBT keycaps and wondering what price I should expect to pay. I am just fine with blanks if that makes it cheaper. Any suggestions?
Offline Pacifist
  • on hiatus
Re: Thick PBT search
« Reply #1 on: Tue, 18 March 2014, 20:19:40 »
the black ones from ivan's gb? Those are $55 IIRC
Offline Vibex
  • Love y'all
« Reply #2 on: Tue, 18 March 2014, 20:21:54 »
Yeah, what the Pacifist said. I'm pretty use he has some left over, you should PM him.
Offline zippox
« Reply #3 on: Tue, 18 March 2014, 20:30:50 »
So $55+ship is about as low as I should expect - good to know. I don't want to waste Ivan's time until I have the green light to buy (will be getting birthday money for caps end of next month), so once I'm in the market I can try and see if he has any left. Otherwise I'll try jumping in on the next GB that has thick PBT blanks for a similar price.
« Reply #4 on: Tue, 18 March 2014, 20:32:55 »
http://www.mechkb.com/review/product/list/id/372/category/5/
These are cheaper, but might not be thick enough.  Plus you'd have higher postage costs.
Offline zippox
« Reply #5 on: Tue, 18 March 2014, 20:34:57 »
You're implying that these are in fact thinner than Ivan's GB keycaps?
Offline Vibex
  • Love y'all
« Reply #6 on: Tue, 18 March 2014, 20:35:45 »
A little after the group buy ends there should be some floating around in the classifieds, so if ivan is out, you can always check there.
Offline Pacifist
  • on hiatus
« Reply #7 on: Tue, 18 March 2014, 20:37:55 »
definitely
Offline JPG
  • Model F is my new passion!
« Reply #8 on: Tue, 18 March 2014, 21:08:01 »
The only others I know of are the vortex dyesub pbt set Feng sold like a year ago. Never saw them after. Got one set myself and a IMSTO from last Ivan GB and they are the same thickness as far as I know.
They were around 40$ + shipping in Feng GB.
Offline CK Briefs
  • formerly calvins1
« Reply #9 on: Tue, 18 March 2014, 21:12:54 »
The ivan gb atm is being sourced from Plum, so it's not from imsto; but apparently it's the same thickness
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline zippox
« Reply #10 on: Tue, 18 March 2014, 21:56:16 »
Will these be the same thickness as the ones sold by Ivan?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=792
Offline zippox
« Reply #11 on: Wed, 26 March 2014, 21:14:19 »
This link was a reference to a thick pbt ducky set. After contacting mechanicalkeyboards they told me it was a 1 quantity item that was taken off a keyboard that was RMA'd. They couldn't tell me if the ducky thick pbt set was equal in thickness to IMSTOs thick PBT caps. I just wanted to update for anyone that was interested in my question.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Thu, 27 March 2014, 07:25:04 »
You could always pick up an older Cherry keyboard like this and take it's keycaps. Though, there are some potential disadvantages to those depending on what keyboard you want to use them on. Several of the keys are not compatible with other keyboards, most specifically the stepped caps lock, spacebar and 1.25 bottom row keys on G81 models. If you find a cheap older G80 that problem does not exist in their case... but more likely to have winkeyless layout with 1.5 modifiers instead.
The deluxe Ducky PBT sets are similarly thick to imsto's KBC/Plum/vintage Cherry.
Offline zippox
« Reply #13 on: Thu, 27 March 2014, 09:31:03 »
So some g81-8000s have PBT caps? Is there an easy way for me to know which of the g81-8000s actually have that vs. ABS?
Offline RESPRiT
  • HHKB = ❤
« Reply #14 on: Thu, 27 March 2014, 10:16:58 »
I don't think any Cherry boards come with stock PBT, but I'm no expert.
Offline ideus
  • Björkö.
« Reply #15 on: Thu, 27 March 2014, 10:18:59 »
Yes they do. Ivan knows what he is talking about. He is kind of an expert on Cherry boards and caps.
Offline RESPRiT
  • HHKB = ❤
« Reply #16 on: Thu, 27 March 2014, 10:54:25 »
Oh whoops, I didn't even realize that he was referring to PBT, although I should have been hinted to that fact based on this thread  :p
Yep, Ivan is the pro, I'll just wait and see what answer he gives for identifying which boards have PBT stock.
« Reply #17 on: Thu, 27 March 2014, 11:27:39 »
Essentially all light colored version with lasered legend have PBT, models with dark keys are POM. All current production G80/G81 models are lasered (or blank in the case of a couple models) one or the other material. Cherry dosen't use ABS anymore since they discontinued models with doubleshots. No current production G80/G81 models have pad printing ABS either that I am aware of though it might still be an option for bulk custom orders.
In regard to PBT, Cherry reduced the thickness of the keycaps by almost half in later years. Winkeyless boards are almost guaranteed to have thick since they were likely made well before the change. On winkey models the tell tales are the original rounded sans typeface, and the sys rq and break are sideprinted not also on the top along with prt scr and pause, and as far as I have seen thick sets never have a newer Windows logo than the 95 style.
Also another thing to watch out for, is the most recent PBT G81 have stabilzer inserts as part of the keycap. These will not work on MX style stabilizer, but you can use them with costar.
« Last Edit: Thu, 27 March 2014, 11:30:04 by IvanIvanovich »
Offline ideus
  • Björkö.
« Reply #18 on: Thu, 27 March 2014, 11:31:41 »
Ivan: I remember I have read about the codes Cherry uses in its boards to differentiate between materials and legends for the caps. But I do not have the references anymore. Do you have some?
« Reply #19 on: Thu, 27 March 2014, 16:10:26 »
I think most of the basic info can be had in this DT wiki article. There was never any indication to keycap material in the model code specifically... at least historically there was not. It was only implied by the type H, P, S, L where H and P is always ABS, S was always PBT, but L could be either PBT or POM depending on color. Now there is since color is only available in one material as in -0 for white (PBT) -1 ? for 2tone I think, which would also be PBT... but I can't seem to find evidence that supports that this moment... -2 for black (POM). But that only applies to later models with 5 letter codes. They didn't do any of that during the 3 letter code era where the trailing /## had to do with PCB revisions. Then even before the 3 letter codes, there was an entirely different model number for everything. Doubleshot or dyesubs... different model number. Different layout... different model number. Different switch... different model number. If they would have kept that up we would probalby be using G80-4365892781905682 by now.
« Last Edit: Thu, 27 March 2014, 16:12:28 by IvanIvanovich »
Offline PolaBurrr
« Reply #20 on: Mon, 31 March 2014, 23:23:40 »
I think the best bet is to wait for those vortex oem thick pbt keycaps to come out of manufacturing. Those seem to fit the bill nicely for most people.
Offline Razor Lotus
« Reply #21 on: Tue, 01 April 2014, 10:54:16 »
Don't think they'll ever come out :(
Offline PolaBurrr
« Reply #22 on: Tue, 01 April 2014, 12:15:30 »
that's how vortex usually does things. They tease something, then no one ever sees it or talks about it until they release it probably 6 months to a year later...
Offline TBone
« Reply #23 on: Wed, 02 April 2014, 18:59:26 »
Are these: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=773 not the vortex caps you're talking about? That listing shows the thickness, but they also come in white on black. Are these not thick enough?
Offline minho
  • i'm kind of back
« Reply #24 on: Wed, 02 April 2014, 21:35:11 »
Those doubleshot PBT's look really nice... and the price is pretty good too. Too bad there's so many group buys for keycap sets and they don't have a Tsangan set or else I'd pick one up right away  :(
Offline Lu_e
Just say NO to ABS keycaps
Offline ideus
  • Björkö.
« Reply #26 on: Thu, 03 April 2014, 09:44:34 »
Yeah, it is a shame this is just a standard ANSI with no options for other layouts, I also think it is a very option and being PBT with DS may last forever. Maybe I will get one, when I have been done with my current GBs.
Offline zippox
« Reply #27 on: Thu, 03 April 2014, 13:21:22 »
I personally like the sharp edges of IMSTO PBT keycaps so even though the Vortex caps seem thick, I don't think it's for me.
Offline ideus
  • Björkö.
« Reply #28 on: Thu, 03 April 2014, 20:19:29 »
IMSTO caps are sublimated, and the new Vortex's caps are DS, I think there is no way to make a direct comparison, just because of that fact. Only if you are referring to the old long available Vortex with dye sub legends.
Offline zippox
« Reply #29 on: Thu, 03 April 2014, 20:24:25 »
I was simply referring to the sharp edges. Not about the fact one is sublimated vs DS. Perhaps you thought I was referring to the font instead of the key edges.
Offline ideus
  • Björkö.
« Reply #30 on: Thu, 03 April 2014, 20:30:34 »
Your comment was crystal clear, but you should explain what type of Vortex caps you are referring to, because now it produces more than one geometry.
Offline zippox
« Reply #31 on: Thu, 03 April 2014, 20:33:19 »
Ah I didn't know that. The ones I have seen have more rounded corners at the base. Do you have a link to ones that you think would be closer to the style I was describing?
Offline ideus
  • Björkö.
« Reply #32 on: Thu, 03 April 2014, 20:36:46 »
I own a set of Vortex that has very square edges, similar to Cherry originals, they have an ugly italic font though, but I think it is the shape you may like, but I do not have any link to those.
