Author Topic: KMAC Screws  (Read 1472 times)
Offline Dr Xav
KMAC Screws
« on: Wed, 19 March 2014, 03:05:14 »
Hi All,
Can any of the K-MAC owners tell me what type of screw are required ?
Re: KMAC Screws
« Reply #1 on: Wed, 19 March 2014, 03:19:11 »
If you can get someone to translate the specifications at the end of this, then you'll have the screw sizes. They're all M3 and M2.. I just don't know what length.
Offline Dr Xav
Re: KMAC Screws
« Reply #2 on: Wed, 19 March 2014, 05:13:21 »
Cool! thanks that is progress ;)
any Korean speakers ? :D
Thanks Photekq
Offline Dr Xav
Re: KMAC Screws
« Reply #3 on: Thu, 20 March 2014, 03:53:54 »
oki I found that the only screws required should be M2 and length 6 and 12 should do the trick.
does anybody knows when I can find the feets (the cushiony bit at the bottom ;) )
