Author Topic: Searching for Progammable Mechanical Keyboards  (Read 2362 times)
Offline undulatus
« on: Wed, 19 March 2014, 06:34:51 »
Hi guys.
Could you help me search for a fully programmable mechanical keyboard (hardware level). Something like a Rapoo v7.
Post your known programmable keyboards.
I need this because I use colemak and I would prefer not switching layouts via OS.
Thank you.
Re: Searching for Progammable Mechanical Keyboards
« Reply #1 on: Wed, 19 March 2014, 06:51:28 »
WASD V2 keyboards have a dip switch that allows colemak at the hardware level
Offline Doesntknowwhattosay
« Reply #2 on: Wed, 19 March 2014, 06:56:59 »
The poker 2 has a fully programmable pn layer. You can also get a custom PCB like the gh60 or one of the sprit ones. There's a open groupbuy here http://geekhack.org/index.php?topic=50580.0
Offline undulatus
« Reply #3 on: Wed, 19 March 2014, 07:21:38 »
Definitely interested in wasd v2, but added programmability would be nice.
Ohh poker 2 has a programmable layer? Is that layer saved in the keyboard itself? Also I would prefer something that is just tenkeyless. A custom would be nice but would require some work and I'm concerned with when the group buys will end.
Thanks for the quick responses :)
Offline jameslr
« Reply #4 on: Wed, 19 March 2014, 07:54:35 »
Sounds like a Phantom or Ergodox is what you're after if you can get your hands on one.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #5 on: Wed, 19 March 2014, 08:25:57 »
Yup, the layer is safed on the keyboard itself. You can use every key as a macro key as well, since you can put up to 15 keypresses on one key.
« Reply #6 on: Wed, 19 March 2014, 08:27:58 »
Keep in mind the lower right Fn and Pn keys aren't programmable, and you have to set it back in the function lock mode (by pressing fn+rshift) every time you unplug it or turn your computer off.
That said, I use my poker 2 with dvorak every day.
Offline undulatus
« Reply #7 on: Wed, 19 March 2014, 09:26:49 »
Ohh.  Yea but hard to get
« Reply #8 on: Wed, 19 March 2014, 09:28:22 »
Where are you located?
Offline undulatus
« Reply #9 on: Wed, 19 March 2014, 09:37:06 »
Wow guys I'm incling to poker 2 now.. Isn't there a dip switch to permalock the colemak layout id set it with? :) please pm me where you bought poker 2
« Last Edit: Wed, 19 March 2014, 21:25:29 by undulatus »
Offline undulatus
« Reply #10 on: Wed, 19 March 2014, 09:42:21 »
I'm currently in LA :) But I'm a tourist and will be gone in a month
Offline undulatus
« Reply #11 on: Fri, 21 March 2014, 02:21:01 »
Hi all,
I went ahead and bought the newly released KBT Race 2. I liked the poker 2 but needed dedicated keys for Function row and arrow keys.
And also because Group Buys are hard to get into xD.
I might consider a custom controller in the future but not for this keyboard. Do continue to post and share more programmable keyboards.  :D
Offline SonOfSonOfSpock
« Reply #12 on: Fri, 21 March 2014, 20:55:52 »
Kinesis Advantage is programmable. Not sure if you'd consider it since it's an ergo board.
