Author Topic: Thoughts about Cooler Master Storm Quickfire TK  (Read 1270 times)
Offline medvednic
« on: Wed, 19 March 2014, 11:10:41 »
Hello, I've been dying to get a mech for some time, I've decided that it will be a TKL brown switch, but the Cooler Master Storm Quickfire TK offers a real numpad although being TKL (I've found myself using the numkeys alot while coding).
I would like to hear your thoughts about it.
btw is it plate mounted?
IBM Model M | CM Strom QFR Stealth MX Brown
Re: Thoughts about Cooler Master Storm Quickfire TK
« Reply #1 on: Wed, 19 March 2014, 11:18:39 »
I wrote a review on the TK here if you're interested in reading that. The only issue that stands out for me is the fact that I don't like the stock CM Storm caps and replacing the bottom row (spacebar, alt, ctrl, etc) is nearly impossible.
Oh and the LEDs on the brightest setting were way too bright. But that's just a minor detail.
If you look at the pictures I posted, it is in fact plate mounted.
Offline medvednic
« Reply #2 on: Wed, 19 March 2014, 12:04:24 »
Thanks dude, will check it out!
