Author Topic: PBT keycaps on older keyboards  (Read 3106 times)
Offline zippox
« on: Wed, 19 March 2014, 23:46:37 »
Is there a way to tell if the keycaps on an older board are PBT? Has ABS basically always been the standard?
Offline Pacifist
  • on hiatus
Re: PBT keycaps on older keyboards
« Reply #1 on: Wed, 19 March 2014, 23:47:27 »
acetone, salt water test
Offline zippox
« Reply #2 on: Wed, 19 March 2014, 23:51:29 »
So what's a socially acceptable way for me to find out if I were looking at a keyboard at a garage sale?
Offline Lastpilot
  • Power stance
« Reply #3 on: Wed, 19 March 2014, 23:53:22 »
PBT sink like rocks in water. Link
So I guess you could grab a cup of water at the garage sale and test it lol.
Offline Pacifist
  • on hiatus
« Reply #4 on: Wed, 19 March 2014, 23:54:10 »
at a garage sale, there's really no point in differentiating whether or not the caps are PBT
all you need to do is take off a key and see if its mechanical. I really doubt somebody is trying to get a lot of money out of a board at a yard sale, and thus will price it really cheap. If its a mech, buy it no matter if its abs or pbt. If its PBT but not a mech, what are you wasting your time for, you won;t be able to use it on any mechs
Offline zippox
« Reply #5 on: Wed, 19 March 2014, 23:57:21 »
Are there any old-school keyboards that have caps that aren't pull-off-able? I.e. is it a safe bet if I try to rip of the Esc key that I won't break it?
Offline Pacifist
  • on hiatus
« Reply #6 on: Thu, 20 March 2014, 00:00:00 »
most boards should be able to pull off the keys. I do not know of any mech that doesn't, hell even all the RDs are easily removeable
« Reply #7 on: Thu, 20 March 2014, 00:03:04 »
Just carry around a keycap remover, preferably a wire one, when you visit such sales.
Less risk of damage to the keyboard if you decide not to buy it.
Offline jacobolus
« Reply #8 on: Thu, 20 March 2014, 04:41:30 »
Take this with a grain of salt. There certainly exist types of switches/keycaps which are relatively easy to break if you aren’t careful when removing the caps. Many keycaps will pop off pretty easily with a keycap puller (or a pair of paper clips, or a butter knife, ...), but if you’re getting a lot of resistance, don’t just yank on it full strength. :-)
« Reply #9 on: Thu, 20 March 2014, 07:24:33 »
There are compatible keycaps on rubber dome keyboards, sometimes PBT. There are doubleshots out there as well. For example, first-generation Apple Design Keyboard and Gateway 2000 Anykey have nice caps.
Carrying around a keycap puller is a good idea. Be especially careful if you think that it is Space Invaders, those springs fly away in a blink.
- Oliver Willis 2026-08-01
