Author Topic: Blue switches  (Read 1397 times)
Offline Dr Xav
Blue switches
« on: Thu, 20 March 2014, 04:20:41 »
Hi All,
I am planning to make a new keyboard using blue switches. I have started lubing and puting stickers. I notices that once lubbed they stop clicking. Is that normal am I doing something wrong?
Thanks for you input !
Offline tbc
Re: Blue switches
« Reply #1 on: Thu, 20 March 2014, 04:36:15 »
yes, you're not supposed to lube the entire thing.  only very specific parts.  as well, you're supposed to use thick lubel.
http://geekhack.org/index.php?topic=53815.0 there are some lube kits being sold in stores mentioned at the bottom of the op
« Last Edit: Thu, 20 March 2014, 04:38:05 by tbc »
Offline Dr Xav
Re: Blue switches
« Reply #2 on: Thu, 20 March 2014, 05:54:37 »
Thanks for the feedback. I was careful not to go everywhere, but I was using the thin lube rather than the thick version.
Good thing I checked after the first 2 ;)
