Author Topic: CM Quickfire Stealth - Stabilizers and key cap size  (Read 3848 times)
Offline medvednic
« on: Thu, 20 March 2014, 15:27:50 »
Hello,
over the last couple of days I've reached a decision to buy a CM Storm Quickfire Stealth (MX Brown), I just have some final questions:
a. what stabilizers are used for the large keys?
b. are all of the keys standard size (for future replacement)?
to be honest I thought first about getting a CM Storm Quickfire TK because of the numpad implementation but I changed my mind due to the non standard keycaps on one of the raws + I'm not sure about how I feel about the font.
IBM Model M | CM Strom QFR Stealth MX Brown
Offline isaske
  • Stop whining!
Re: CM Quickfire Stealth - Stabilizers and key cap size
« Reply #1 on: Thu, 20 March 2014, 15:30:03 »
Not sure about the keys - I'm pretty certain that it uses costar stabilizers though
HOW DO I COMPUTER?
  • Live long and prosper
« Reply #2 on: Thu, 20 March 2014, 15:31:02 »
100% sure they're Costar stabs, and 95% sure the keys are all standard layout.
tp thread is tp thread
Offline medvednic
« Reply #3 on: Thu, 20 March 2014, 15:39:16 »
Thanks, btw is the CMStorm Quick Fire TK Stealth available to purchase somewhere?
Offline wharrislv
« Reply #4 on: Thu, 20 March 2014, 17:05:54 »
I recently picked up a standard set of white keycaps for a CM stealth and everything fit fine.  The stabs as discussed above are costar.
Current daily drivers : HHKB Pro 2, HHKB Lite in a server rack, A few Filco numpads in brown and blue, Pure Pro in Brown with Rainbow PBT, CM Ninja in Brown with white engaved PBTs, two Model Ms 89 and 91 with a few red esc, Ergodox full in clear with blanks, a jdcarpe built 40% awaiting some Round 6 keycaps, and soon a Gon custom.  Hundreds more on site at a mechanical friendly work site where I am the purchaser.  If it exists, I probably have used one!
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #5 on: Thu, 20 March 2014, 17:10:29 »
Quickfire TK stealth doesn't have standard size keycaps, and has cherry stabs. it has 1.5-1-1.25 and 1.25-1-1-1.5 on the bottom row and has a unique sized spacebar.
I got boards.
Offline medvednic
« Reply #6 on: Fri, 21 March 2014, 14:06:21 »
Thanks...
last question - is it worth paying for SquareTrade 2-Year PC Peripherals Protection Plan that is offered by Amazon, or does CM's warranty is good enough?
btw I don't live in the US.
« Reply #7 on: Fri, 21 March 2014, 14:12:32 »
Thanks...
Does SquareTrade warranty international items?
Offline medvednic
« Reply #8 on: Fri, 21 March 2014, 14:39:13 »
IDK, it is said something about "Worldwide Coverage", but now I read the description and it says:
"If you need a repair while abroad, send us a valid repair receipt for your item and we will reimburse you within five business days."
so probably it is for US purchases only...
Offline phx
« Reply #9 on: Fri, 21 March 2014, 15:26:28 »
these keyboards dont usually break, even if it does most of the time you can easily repair it.
plus I think I voided the warranty on all my boards by opening them up to lube. >_>
Offline medvednic
« Reply #10 on: Sat, 22 March 2014, 14:46:39 »
For my knowledge, does the CM warranty works for international purchases? if I will buy the product from Amazon for example?
« Reply #11 on: Sat, 22 March 2014, 19:33:07 »
That might be a question for CM directly, unless Carter or Rajiv is lurking around here ...
I have QFR and QFS.  Both are fantastic boards, haven't missed a beat.  The layout is totally standard.  And definitely Costar stabilisers.
