Author Topic: How thick should the plate mounting plate be?  (Read 1682 times)
Offline Mr Fister
« on: Fri, 21 March 2014, 04:24:03 »
I am currently planing to build a control panel for a raspberry pi home automation project using Cherry mx blue switches.
The switches will be plate mounted but I wasn't able to find out how thick the plate should be?
So basically what is x?
**** I failed editing the picture
« Last Edit: Fri, 21 March 2014, 04:26:07 by Mr Fister »
Offline Mr Fister
Re: How thick should the plate mounting plate be?
« Reply #1 on: Fri, 21 March 2014, 04:29:31 »
this is right.
Offline yasuo
  • spanengan puyeng newbie
« Reply #2 on: Fri, 21 March 2014, 04:34:29 »
standart thick plate is 1,5mm
Logitech MK220 Colemak DH
Offline Mr Fister
« Reply #3 on: Fri, 21 March 2014, 05:54:04 »
Thanks
Offline strict
  • TKL Zealot
« Reply #4 on: Fri, 21 March 2014, 08:42:53 »
16 gauge (0.0625") plates work very well, but I believe the exact size Cherry calls for is 0.060".
Offline jacobolus
« Reply #5 on: Fri, 21 March 2014, 09:24:47 »
You can use a thicker plate than that if you want (e.g. there seem to be lots of people who mount MX switches in substantially thicker acrylic plates), but it won’t be able to clip in to the other side, so the little plastic clips will get a bit bent out of their usual shape. This is fine if you are making a keyboard to keep indefinitely, but may not be ideal if you want to use the switches for something else after.
For instance, though, the typical Ergodox (such as the version MassDrop ships) uses a thick acrylic plate.
If you can get a 1.5mm metal plate, or similar, that’s better.
