Author Topic: Wrist Rests  (Read 12728 times)
Offline Viett
Wrist Rests
« on: Mon, 30 March 2009, 19:17:09 »
Are these worth buying? If so, which are the best to buy?
I have never really used one for an extended period of time, but I figure they might be comfortable.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline bigpook
Wrist Rests
« Reply #1 on: Mon, 30 March 2009, 19:29:04 »
pic?
Offline FKSSR
Wrist Rests
« Reply #2 on: Mon, 30 March 2009, 20:08:16 »
The general consensus of many people here is that the cheap, flat foam wrist rests are best.  A thread here ended up with a bunch of us talking about them (just read from that point on).
Add me on Steam | Twitter
Offline o2dazone
Wrist Rests
« Reply #3 on: Mon, 30 March 2009, 20:55:57 »
Thanks for posting this. I've been using rolled up microfiber cloth. I wouldn't mind fabbing up one of those wooden HHKB rests, but I'd like to grab up a piece of 2x4 and a cheap gel wrist rest just to test them both out first.
photos thanks to megarat
Offline Viett
Wrist Rests
« Reply #4 on: Mon, 30 March 2009, 21:04:36 »
I might just get a cheap, flat one like this: http://www.amazon.com/Fellowes-58044-Wrist-Pad-Black/dp/B00006B8I5/ref=pd_bbs_11?ie=UTF8&s=electronics&qid=1238464881&sr=8-11
Such a shame to pay so much in shipping, though. I might just take a trip to Best Buy.
Offline rdjack21
Wrist Rests
« Reply #5 on: Mon, 30 March 2009, 21:51:30 »
Quote from: Viett;26197
Yea I just bought one from them yesterday and paid $20 for it. It is a memory foam one it does the job but then I ran across this one while looking at boards on the diatec site.
http://www.diatec.co.jp/shop/det.php?prod_c=575
and thought it would look good with a filco tenkeyless or that new realforce 87U but it is not cheap it is about $40 then you have to add shipping from japan but if you are already getting something might be worth looking at.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline BigWopHH
    • http://www.hothardware.com
Wrist Rests
« Reply #6 on: Mon, 30 March 2009, 22:14:24 »
Quote from: rdjack21;26201
I'm using one of the Filco wrist rests with my board and generally like it because it is much wider than most readily available wrist rests, but it is pretty hard and the leather (or pleather?) does tend to get warm after a couple of hours typing.
  • Topre Realforce 103UB
  • Topre Realforce 87U
  • ABS M1
  • Solidtek ASK-6600U
  • Dell AT101W
  • Das III Pro
  • Scorpious M10
  • Cherry G80-3000LSCRC-2 (Blues)
  • Cherry G80-3000LXCEU-2 (Browns)
  • Unicomp Customizer 104
  • Steelseries 7G
  • Filco Majestouch FKBN104M/EB < Has Become My Daily Driver. Really Diggin\' It.
[/SIZE]
Offline rdjack21
Wrist Rests
« Reply #7 on: Mon, 30 March 2009, 22:49:07 »
Quote from: BigWopHH;26205
That was one of the things I noticed about it and thought I would like so I ordered one with the keyboard I just ordered.
But I have also been thinking about making my own out of memory foam. Over at overstock.com you can get it for  $40-50 depending on what kind you want. That way I could cut it to fit for every board I have and still have some left over. But I would also have to figure out a cover but still I may end up doing it at some point. Mostly because memory foam would be very comfortable. Oh here is the link for overstock if anyone wants it: http://www.overstock.com/Home-Garden/Memory-Foam/2795/subcat.html
Keyboards
Black Alps: ABS M1
Offline lam47
Wrist Rests
« Reply #8 on: Tue, 31 March 2009, 02:52:31 »
I hope to have my HH style ones available soon. They will have brown leather or red. I even have some antique green leather which is very nice.
Unfortunately ill health has prevented me from getting these done sooner but I will give all long time GH members a good deal.
I should have wood choices and size choices available too.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline itlnstln
Wrist Rests
« Reply #9 on: Tue, 31 March 2009, 06:54:01 »
Quote from: lam47;26235
I can't wait for these. :)
Other than something that lam can create, the best ones I have have ever used are the cheap, thick mousepad types.  You can get them on eBay for dirt cheap.  I bought four of them last time.  I keep two at work and two at home.  I like my rests to be firm and no higher than about 3/4 of an inch (or equal in height to the front edge/top of the keyboard).  If they are too high, it's uncomfortable to type on.
Offline dougy
Wrist Rests
« Reply #10 on: Tue, 31 March 2009, 08:10:31 »
I've been using a bead-filled one from imakproducts.com for a couple of years. Provides support over a large area and is easily adaptable to ergo boards.
Offline FKSSR
Wrist Rests
« Reply #11 on: Tue, 31 March 2009, 08:11:26 »
I think a red lam-creation could be great, but I'm curious if the wood would eventually cause my wrists to hurt.  I like wrist rests because wrists get a rest on softer material than my desk when I set them down.
Offline rdjack21
Wrist Rests
« Reply #12 on: Tue, 31 March 2009, 08:24:25 »
Quote from: dougy;26278
Those do look to be pretty comfortable I may have to get one. I want something soft as well. I have used the hard ones and they are OK for shorts stints but for long stints of typing I much prefer the soft ones.
Keyboards
Black Alps: ABS M1
Offline itlnstln
Wrist Rests
« Reply #13 on: Tue, 31 March 2009, 08:37:09 »
Quote from: FKSSR;26279
They would be covered in leather (over a pad, if I am not mistaken), so they would be less than hard. I, personally, prefer firmer rests since it allows me to move around the 'board a little more easily.  I mainly use rests to elevate my hands in relation to the keyboard to keep my wrists flat.
Offline MANISH7
Wrist Rests
« Reply #14 on: Tue, 31 March 2009, 09:53:22 »
Quote from: Viett;26183
Just remember NOT to use them WHILE your fingers are typing. These are to be used while you are taking a typing break and resting your wrists. I personally don't use wrist wrests. When I do take a typing break, I just use my chair armrests. Different strokes for different folks.
Offline chongyixiong
Wrist Rests
« Reply #15 on: Tue, 31 March 2009, 10:49:56 »
Well, here's a wrist rest that I made using very cheap materials.
A block of thin wood, roughly about 0.8 cm, and a whole piece of Polyurethane foam (those that are used to wrap around air-conditioning tubings to prevent condensation) that is about 1.8cm thick.
What I like about this is that the PU foam is quite firm, yet there is a slight depression made when my wrists are above it. Sort of like emulating leather, but much cheaper and nice to make. Goes well with my Filco Blank Tenkeyless as well.. :P
Total cost? $0.0 since I took the parts from a garage junk area, lol!
Enough with the talk, here are some pictures! I highly recommend you guys to start making your own wristwrests.. well, not to the level of perfection and beauty that one of our Geekhacker here has been able to reproduce. His self-made wristwrest with mahogany are much better than mine, and yes... I do find them sexy as well.
Offline itlnstln
Wrist Rests
« Reply #16 on: Tue, 31 March 2009, 11:50:50 »
Quote from: webwit;26313
That looks very nice and soft...yummy! I don't like the hard ones, if any. It would be hard to beat that, unless it is made of titties.
I LOLed.  That's hilarious.  You could use silicone if you like them firmer.
Offline o2dazone
Wrist Rests
« Reply #17 on: Tue, 31 March 2009, 12:22:17 »
Titty wrist rest? I might have to talk with my wife tonight...
Offline Chloe
  • Switch Kitten
Wrist Rests
« Reply #18 on: Tue, 31 March 2009, 12:27:16 »
For lower profile keyboards such as the Cherry G84-4100 and G80-1800 I like to use a small towel folded in half, with the rest under the keyboard to dampen the sound of the desk. I quite like the look of these by favfemme, basically the same idea but they also double as dust covers and are anti-static:
http://tenant.depart.livedoor.com/t/as_blj/item3253032.html
http://auction.item.rakuten.co.jp/10000238/a/10016900/
Quote from: itlnstln;26283
I find this too. I tried to make my own out of memory foam but found it too soft and it got in the way unless squished. It might be nice if you rest as you type though.
Offline itlnstln
Wrist Rests
« Reply #19 on: Tue, 31 March 2009, 12:40:54 »
I don't even use a rest for my ML-4100, but I like the towel idea if only for softness.  For the record, I am speaking from the perspective of a wrist rester; I never did like hovering over the keyboard.
Offline Chloe
  • Switch Kitten
Wrist Rests
« Reply #20 on: Tue, 31 March 2009, 13:05:06 »
It is very soft, but there is also the firmness of the desk too. The smallest Supima is just the right size for small keyboards.
Offline Viett
Wrist Rests
« Reply #21 on: Tue, 31 March 2009, 14:35:38 »
Quote from: MANISH7;26295
I'll keep this in mind. Although I touch type, I can get lazy at times. I might try one of these DIY solutions, if I can find the right stuff.
Offline FKSSR
Wrist Rests
« Reply #22 on: Tue, 31 March 2009, 19:13:34 »
are you kidding?  unbelievable.
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
Wrist Rests
« Reply #23 on: Tue, 31 March 2009, 22:31:21 »
In the interest of your medical health I present you this:
http://www.dealextreme.com/details.dx/sku.10544
Mount on a single board for mouse rest. Two for keyboard.
- Ripster
Should I mount those with staples or nails?
Also, for those interested, I'll have a few Filco wrist rests in next week to try out. So they might be available on the site soon (if they're worthy).
Offline rdjack21
Wrist Rests
« Reply #24 on: Tue, 31 March 2009, 22:49:26 »
Quote from: majestouch;26385
LOL Of course after I ordered some with my Realforce 87U :( I will not tell you how much I paid for them either because it was to much way to much.
Keyboards
Black Alps: ABS M1
