Author Topic: Where can I get a PBT 4.5x spacebar?  (Read 11836 times)
Offline berserkfan
« on: Sat, 22 March 2014, 22:02:49 »
I have a JIS layout Filco Majestouch 2, and want a PBT spacebar for that.
I've rarely seen SP offer one in their inventory. The latest is a color I definitely do not want - brown.
Occasionally there are group buys but these involve whole sets and spacebars are ABS anyway.
Is there a supplier or an obscure group buy?
Would prefer to get a white, off-white, cream or yellow PBT spacebar. Light colors are good because I can dye them if I want. Anyway my Filco's spacebar is black.
Offline BlueBär
Re: Where can I get a PBT 4.5x spacebar?
« Reply #1 on: Sun, 23 March 2014, 09:17:04 »
SP just made their first PBT spacebars, and I don't think there are many suppliers who made some. And then additionally the 4.5 length... I don't think that something like a 4.5 PBT spacebar exists right now. I mean even 4.5 ABS spacebars are rare.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 23 March 2014, 13:21:30 »
PBT Pure Pro set?
Offline BlueBär
« Reply #3 on: Sun, 23 March 2014, 13:27:08 »
PBT Pure Pro set?
Is the spacebar PBT though? Not sure.
Offline berserkfan
« Reply #4 on: Sun, 23 March 2014, 21:49:15 »
PBT Pure Pro set?
Um... not gonna buy a Pure Pro just for the spacebar. That's worse than spending $500 on a brobot or whatever keycap that is at least collectible.
Offline ideus
  • Björkö.
« Reply #5 on: Sun, 23 March 2014, 22:18:16 »
SP has 4.5u space bars for sale in SA profile. I supose they are ABS though.
Offline berserkfan
« Reply #6 on: Sun, 23 March 2014, 22:49:46 »
Yes, brown ABS. IE it looks like and lasts as long as... s***.
Offline BlueBär
« Reply #7 on: Mon, 24 March 2014, 06:58:15 »
Pretty sure you can buy just the keycaps on taobao or a similar site.
Offline berserkfan
« Reply #8 on: Mon, 24 March 2014, 07:46:28 »
Ah, if I could find them on taobao, why would I be posting here?
Offline BlueBär
« Reply #9 on: Mon, 24 March 2014, 07:50:29 »
Offline Grendel
« Reply #10 on: Mon, 24 March 2014, 13:41:52 »
Don't see a Pure Pro set there.. ;P
- I'm game !
Offline BlueBär
« Reply #11 on: Mon, 24 March 2014, 13:45:42 »
Then I would recommend you to wear glasses...
Offline berserkfan
« Reply #12 on: Mon, 24 March 2014, 17:14:07 »
I appreciate your good intentions BlueBaer, but I'm not paying $50 for a single spacebar. That is not a practical solution, to get an entire set that does not even fit my designated keyboard (which is not a KBT) for just one space bar.
(That's roughly how much it would cost to buy an entire KBT Pure PBT set from them, plus proxy and shipping fees.)
Still you have inspired me. Tomorrow I'll try contacting the seller. He might have some sets broken up.
Offline FuriousGeorge
« Reply #13 on: Mon, 24 March 2014, 17:33:36 »
Subscribing. I'm interested in options for my Tex Beetle.
Offline BlueBär
« Reply #14 on: Mon, 24 March 2014, 17:42:33 »
Just think of it as a very expensive spacebar ;)
Maybe you who have those keyboards with small spacebars should organize a GB now that SP is starting to do PBT spacebars.
Offline ideus
  • Björkö.
« Reply #15 on: Mon, 24 March 2014, 19:26:55 »
If you want to run a GB for PBT 4.5u space bars I may be in for a black, dark gray, light gray and white. You should know that SP has a mold for that size, and the same mold that is used for ABS can be used for PBT. It is SA though.
Offline berserkfan
« Reply #16 on: Mon, 24 March 2014, 22:46:04 »
[/quote]
Can't do a group buy for SP stuff; I'm not located CONUS and the logistics will be so much more troublesome.
But if it is a question of negotiating with a Taobao seller for like, 10 spacebars and sending some to the US for 3-4 people, that's doable.
Offline ideus
  • Björkö.
« Reply #17 on: Mon, 24 March 2014, 23:07:54 »
It sounds good to me.
Offline Grendel
« Reply #18 on: Mon, 24 March 2014, 23:47:12 »
I do, TYVM. Since you seem to know your chinese -- the selection buttons seem to be labeled only "Poker 2" or "Pure". Does the latter include the extra Pro caps ?
- I'm game !
Offline BlueBär
« Reply #19 on: Tue, 25 March 2014, 06:07:41 »
I don't know actually, but I guess so. Maybe Imsto or Qtan can help you out.
Offline lolkey
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline BlueBär
Offline ideus
  • Björkö.
Offline Grendel
« Reply #23 on: Tue, 25 March 2014, 13:25:46 »
Try here maybe - http://www.easy-taobao.com/taobao/list1?keyword=pbt+spacebar&cateid=
Enter "pbt pure pro" (no quotes) into the search of that site...  :eek:
- I'm game !
Offline BlueBär
« Reply #24 on: Tue, 25 March 2014, 15:35:18 »
How can I tell wich one is the right size.
The keycaps are usually associated with the Pure Pro somewhere in the article descritption.
Offline ideus
  • Björkö.
« Reply #25 on: Tue, 25 March 2014, 17:25:58 »
I checked a couple of the items description carefully, and I was not able to tell wich size are them.  :(
Offline BlueBär
« Reply #26 on: Tue, 25 March 2014, 18:32:54 »
Those from that link are all 6.25.
Offline ideus
  • Björkö.
« Reply #27 on: Tue, 25 March 2014, 19:48:26 »
I used pure pro for searching and you might be surprised of the items I got, everything but spacebars.
Offline BlueBär
« Reply #28 on: Tue, 25 March 2014, 19:55:41 »
Offline ideus
  • Björkö.
« Reply #29 on: Tue, 25 March 2014, 19:58:23 »
Offline PlastikSchnittstelle
« Reply #30 on: Wed, 16 November 2016, 09:13:00 »
hi,
I also have an old Pure Pro laying around. the 4.5U spacebar and most of the 1U modifiers made it impossible for me to populate the board with a custom keyset so far.
I just found the XDA-Milestone GB from keyclack. this set has an optional 4.5U spacebar and all the 1Us needed for the Pure-Pro.
just wanted to let u know.
« Last Edit: Wed, 16 November 2016, 09:59:07 by PlastikSchnittstelle »
