Author Topic: Question about DK2087  (Read 2861 times)
Offline Harms
« on: Sun, 23 March 2014, 12:01:05 »
Hi everyone I was just wondering if this keyboard has back lighting, http://products.ncix.com/detail/ducky-dk2087-zero-red-switch-37-90672-1374.htm. The picture that ncix has up is wrong, its actually a tkl board; thank you.
Re: Question about DK2087
« Reply #1 on: Sun, 23 March 2014, 12:19:58 »
From what I have been able to determine, the ducky zero TKL is not backlit.
The keycaps do not appear to be backlight-compatible, and other vendors do not list backlighting as an option
see http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=662
Offline BlueBär
« Reply #2 on: Sun, 23 March 2014, 13:11:42 »
The only backlit keyboard from the Ducky Zero series is the Zero DK2108S.
Offline Key-Fu
  • ¡Viva la Ctrl+Z!
« Reply #3 on: Sun, 23 March 2014, 21:55:56 »
The DK2108 only has 4 backlit keys (Caps Lock, Num Lock, Scroll Lock, and F12).  As BlueBar said, the only member of the Zero family to have full board backlighting is the DK2108S (S for Shine).  I don't know if they make a TKL variant.  The Ducky superkey and spacebar icon is different on the S version.  It looks like Zero Duck but with a little angler fish glowing bob on it's head.
http://www.duckychannel.com.tw/en/ZERO_DK2108S.html
Good luck on your search.  :)
Offline Harms
« Reply #4 on: Sun, 23 March 2014, 23:08:55 »
Thanks guys, I don't know what one i should go with; CM QFR or this? :O
« Reply #5 on: Sun, 23 March 2014, 23:22:24 »
Ducky is full size, QFR is not.
Both are good reliable boards.
It comes down to whether you need the numeric keypad or not.
Offline Pacifist
  • on hiatus
« Reply #6 on: Wed, 02 April 2014, 22:02:25 »
pretty sure the full size image is a mess up on ncix's part
« Reply #7 on: Wed, 02 April 2014, 23:03:59 »
In the Ducky part number DK2108 (auoted above), the "108" part refers to 108 keys i.e. the standard 104 keys plus the Ducky extra four function keys.
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 02 April 2014, 23:14:26 »
my mistake
thought OP was referring to the board in the OP, http://products.ncix.com/detail/ducky-dk2087-zero-red-switch-37-90672-1374.htm not the 108 posted by key-fu
« Reply #9 on: Wed, 02 April 2014, 23:50:35 »
my mistake
Heh for once I actually read the preceding post before replying :p
