Author Topic: 60% keyboards?  (Read 3675 times)
Offline moonman743
60% keyboards?
« on: Sun, 23 March 2014, 16:52:43 »
Are there any 60% keyboards that are considered high quality.
I would want one that has the exact layout of a normal keyboard.
Is key spacing or size any different?  what exactly does "mini" suggest or is it basically anything smaller than tkl?
« Last Edit: Tue, 25 March 2014, 01:17:55 by moonman743 »
Offline Pacifist
  • on hiatus
Re: 60% keyboards?
« Reply #1 on: Sun, 23 March 2014, 17:06:12 »
korean custom--eagle i think? or viper
Offline blingcaps
Re: 60% keyboards?
« Reply #2 on: Sun, 23 March 2014, 21:51:12 »
the poker 2 is the only one which has the same layout as a TKL.  all the other 60% boards make compromises and result in non-standard sizes, usually to fit in the arrow keys.
the picture you posted is a pure.  the right shift is non-standard to fit in the extra key.
Offline 1pq
  • Hipster Doofus
Re: 60% keyboards?
« Reply #3 on: Sun, 23 March 2014, 23:09:01 »
Most customs allow for standard 60% placement
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline moonman743
Re: 60% keyboards?
« Reply #4 on: Mon, 24 March 2014, 01:42:05 »
Thanks guys.  the poker 2 looks nice.  Ive heard a lot of talk about "korean" custom keyboards, but i cant seem to find much on any kind of custom keyboards. if anyone can link me to a couple of these places id appreciate it.
Offline Doesntknowwhattosay
Re: 60% keyboards?
« Reply #5 on: Mon, 24 March 2014, 02:23:56 »
Check out sprits groupbuy in the groupbuy subforum. He also has a 60% keyboard and can assemble it for you.
Offline sth
  • 2 girls 1 cuprubber
Re: 60% keyboards?
« Reply #6 on: Mon, 24 March 2014, 02:58:44 »
if you want build quality just get a HHKB and learn the barely-different layout. most people really enjoy it once they get over the minuscule changes in habit.
Offline Mainian
Re: 60% keyboards?
« Reply #7 on: Mon, 24 March 2014, 07:42:20 »
I actually didn't like the HHKB for coding... the arrow key layer is just painful to use for long sessions. Other than that, I loved the HHKB Pro 2. And if I didn't use arrow keys so much, I wouldn't have sold it :(.
Have a leopold FC660C... which I might get a realforce tkl sometime soon. Topre is nice.
Offline lowmagnet
Re: 60% keyboards?
« Reply #8 on: Mon, 24 March 2014, 08:01:05 »
I actually didn't like the HHKB for coding... the arrow key layer is just painful to use for long sessions. Other than that, I loved the HHKB Pro 2. And if I didn't use arrow keys so much, I wouldn't have sold it :( .
That's why I'm interested in the space-fn keyboard layout. I like the idea of chording the space bar instead of the out-of-the-way fn-key. Alternately, there's a way of re-mapping win and fn to swap places, then swap caps lock and win key on the left to get a more convenient fn-key. I've yet to achieve this however.
I like the 60% format ok enough for programming, mainly because I use IntelliJ and RubyMine most of the time, which have some pretty crazy useful keyboard shortcuts.
Re: 60% keyboards?
« Reply #9 on: Mon, 24 March 2014, 18:13:11 »
Maybe keep an eye out for the CM Novatouch - a TKL keyboard with Topre switches and Cherry MX compatible stems.
Probably coming out later this year.
Offline Pacifist
  • on hiatus
Re: 60% keyboards?
« Reply #10 on: Mon, 24 March 2014, 18:18:04 »
confirmed coming out later this year
Offline wthefourth
Re: 60% keyboards?
« Reply #11 on: Tue, 25 March 2014, 00:02:53 »
Had some friends try those out at SXSW this year. They're both on board to buy them as soon as they drop, and have been hyping me up for them since they used them. I will officially own more keyboards than computers after I buy one when they drop.
Offline Bucake
Re: 60% keyboards?
« Reply #12 on: Tue, 25 March 2014, 00:17:23 »
i would recommend the pure pro, but i presume that's not the layout you want.
i own a pure pro with pbt keycaps myself. this plate-mounted beauty just feels incredible :)
again; i presume you're looking for a different layout, but i'd certainly vouch for the pure pro (pbts! ;p) when it comes to quality.
have fun finding your keyboard! :)
Offline moonman743
Re: 60% keyboards?
« Reply #13 on: Tue, 25 March 2014, 01:16:19 »
Nice info!  Although i made a post about 60%,  tkl may be good enough, im just waiting for mine to arrive (and i wanted more info on 60% anyway).
 Ducky DK9087G2 TKL (Black Chery)  will be my first mechanical.
I've been using an orbweaver to the left of my lyocosa and i think it would be a better setup with a smaller keyboard.
 I specifically like the design of the novatouch with the front print and backliting. thats something i haven't seen before.
 http://www.brightsideofnews.com/news/2014/1/7/cooler-master-suite-at-ces-2014.aspx   (keyboards at the bottom)
also if  i think about it i would just want the spacing of alphanumeric and left modifiers to be the same and i think id be fine.
Offline sth
Re: 60% keyboards?
« Reply #14 on: Tue, 25 March 2014, 02:07:01 »
there is something hilarious to me about keyboards at sxsw. former glory...
