Author Topic: Switching keys around (through software)  (Read 1908 times)
Offline uzoc
« on: Sun, 23 March 2014, 19:51:58 »
Need some help, suggestions...
I have a TypeMatrix 2030:
58525-0" alt="" class="bbc_img" />
I love the keyboard layout, scissor switches, key travel, etc, but I have something that makes me put it away, every time I start using it...
The Enter, Backspace and Delete keys are in the middle (makes sense, and its OK) but I can't get used to it!
Until I do, I would like to map some of the special keys on the right.
I'm looking for the simplest to use/configure, less memory intrusive app out there.
I've seen the Microsoft Keyboard Creator: http://msdn.microsoft.com/en-us/goglobal/bb964665.aspx
But not sure if it does, what I want it to do (above).
Any tips/ideas?
« Last Edit: Sun, 23 March 2014, 19:57:45 by uzoc »
Offline ideus
  • Björkö.
Re: Switching keys around (through software)
« Reply #1 on: Sun, 23 March 2014, 20:01:58 »
Give SharpKeys a try. It is a registry based software, so it does not need anything to load in RAM besides OS files. I am in the understanding you are using a version of Windows.
Offline uzoc
« Reply #2 on: Sun, 23 March 2014, 20:48:07 »
It doesn't recognize any special TypeMatrix keys,
But I found KeyTweak it allows you to recognize (and map to) any key with the "full teach mode".
I'll keep searching, if anyone finds another, let me know!
