Author Topic: Realforce 23u Disassembly  (Read 6146 times)
Offline ComradeSniper
  • HHKB Pro
« on: Mon, 24 March 2014, 17:08:32 »
Anyone ever take theirs apart? After undoing the screws and bottom tabs it still feels like there are two tabs on the top side of the case that won't pop off, and I'm scared of breaking something if I just pull on it  :-[
Offline jalaj
Re: Realforce 23u Disassembly
« Reply #1 on: Mon, 24 March 2014, 17:45:30 »
There's one screw remaining that is behind one of the corner rubber grips/feet.
  • HHKB Pro
« Reply #2 on: Mon, 24 March 2014, 17:59:30 »
That did it, thanks a bunch!
« Reply #3 on: Sat, 05 September 2015, 20:15:54 »
I know this is old but THANK YOU, felt like I was going to break mine in half lol.  :cool:
« Last Edit: Sat, 05 September 2015, 20:25:01 by dustinhxc »
Offline johntron25
« Reply #4 on: Thu, 05 September 2024, 16:57:18 »
I know this is old but THANK YOU, cheers from 2024!
